Old 10-11-2010, 11:57 AM   #1
Lance-ftw
Lance-ftw's Avatar
MSD ignition wired directly to battery.
Is this a problem?
I can't find a good isntallation manual online but my MSD ignition system is powered directly from the battery (assuming that means it's always hot) is this proper, and if not proper is it dangerous in any way or bad for the ignition/truck/starving pygmies in guam?
I figure it should be on ACC power and not full 12v constant but I'm not sure so I figured I'd come here and ask
Thanks in advance for the help.
Lance-ftw is offline   Reply With Quote
Old 10-11-2010, 12:52 PM   #2
Gobbles
Gobbles's Avatar
Re: MSD ignition wired directly to battery.
Not sure which model you have, but here are some schematics for the 6 series. The few I looked at all have a hot going directly to the battery.
http://www.msdpower.com/support/inst...p?cat=download
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 10-11-2010, 05:54 PM   #3
grs
I think it should be hot with the key on. Not hot all the time.
grs is offline   Reply With Quote
Old 10-11-2010, 06:08 PM   #4
71 super
71 super's Avatar
I have had both the 6 and the 7 series and both were wired directly to the battery per the manufacturers instructions.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 10-11-2010, 06:28 PM   #5
SactoJim
SactoJim's Avatar
I believe there is a wire that does go to battery and another trigger wire you wire to your ignition switch. Nice little semi-theft deterrent is to run a toggle switch or similar in line with the ignition wire and put it within reach but out of site.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-11-2010, 07:02 PM   #6
El Jay
Gone to greener pastures
The 6 series box is supposed to be wired directly to the battery, both the hot and the ground sides; so says MSD in their instructions.
For my bona fides, I have a 6 series box on my '69.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 10-11-2010, 08:07 PM   #7
aintmisbehavinn
I jumped mine off the fuse block on the side, works perfect and it's inches from the battery. The positive wire running from the postive lead to the box is easy and no splicing or cutting, no wire to fall off when you disconnect. Take the white wire from the box run into a hidden place an wire to toggle switch for on off to disable ignition. Mine is hidden away along with a fuel cut off. One excellent benefit of MSD and you can't jump any wire to the starter or coil, you won't have ignition unless you can figure out were it grounds which will buy you time.
aintmisbehavinn is offline   Reply With Quote
