Changing Support Bearing
so my center support bearing is pretty worn out so i bought a new one but its different from the one i have. did they change the design cause ive looked up the pn and its supposed to fit, but the place i got it from is known for giving me the wrong part
eh ![]() 1970 Chevy C20 daily driver ![]() 1975 GMC Jimmy 4x4 project ![]() 1966 GMC C10 Dad's project ![]() Last edited by Camper Power; 10-11-2010 at 05:33 PM. |
Junior Member
Re: New Support Bearin
That looks like the one in my '67 C-20 with a granny 4 speed.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
well mine has a turbo 350 trans and a d60 axel if that changes anything
eh ![]() 1970 Chevy C20 daily driver ![]() 1975 GMC Jimmy 4x4 project ![]() 1966 GMC C10 Dad's project ![]() |
Apart from the difference in appearance, are the mounting centers the same?
Ray |
the mounts to the frame seem to be correct, im more worried about where the bearing itself sits. cause the orginal one sits on the driveshaft while the new one looks like it needs to be where the splines are. would i have to get the end of the front driveshaft changed to make it work? i just dont want to have to spend much money on it cause i am short on cash at the moment
#6 | |
(1) The bearing is tight on the splines (2) The bearing doesn't interfere with the yoke on the rear shaft Ray |
All the one I have seen look like your new one. Maybe the old one was replaced and not exactly correct.
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 10-12-2010 at 05:35 PM. |
Sameyrasmea72, what are those widgets under your tranny mount that the green arrows are pointing to?
Ray |
Sorry about this pic, I used it awhile back to show somebody something else. Those are used on BB trucks w/th400 and are used to hold the e-cable out of the way of the driveshaft. (AS FAR AS I CAN TELL)
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 10-12-2010 at 05:53 PM. |
thanks sameyrasmea72, thats exactly what i needed to see. it is a leaf sprung rear end so that might be why its different but now i dont see why it wouldnt work
