1966 chev short bed
I have a 1966 Chev short bed and want to put disk brakes and a new rear end on it.
I have found a 1972 GMC long bed that I think i can use for parts. What I need to know is will the rear end bolt up to my 66 without cuting and welding and will all of the other parts work..Front cross member,Power brakes,Automatic trans crossmember, drive shaft? Any comment will be helpful. |
![]() Join Date: Nov 2009
Re: 1966 chev short bed
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
![]() Quote:
There is alot of info there. The front stuff is a basic swapping of parts, plus adding the disc brake master cylinder and proportioning valve from the '72. The rear will be a direct swap also as long as both trucks are either coil or leaf sprung.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-12-2010 at 07:45 AM. |
None of the later suspensions are a direct bolt up. They are not a difficult swap but still need a little massaging. The front will need at least a few new holes and a brake line modification and the back will need a little welding to make it work with truck arms. Sean
#5 | |
I'm trying to learn something here. The Suspension section covers this topic in great detail. (My answer was a quick overview). The front can be done without changing the crossmember itself. (a-arms out, parts swap) Brake lines go with the M/C swap. If the OP has a donor truck,... I would think he would have everything to to the swap.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-12-2010 at 07:51 AM. |
Happy to be here
![]() Join Date: Mar 2000
Good observation, but you have to remember not "all" GMC's came with leaf springs, just as not "all" Chevies came with coil.
Here I thought, half ton GMC,......... leaf spring truck. The things you learn on this site! Sean
60-66 Nut
![]() ![]() Join Date: Mar 2007
It also depends if the GMC donor is a C10 or C20 whether the parts are going to work for the OP. If it is a C10 and has rear coils, it should be a straight forward swap. You will have to shorten the driveshaft though. That usually doesn't cost that much to have done.
Happy to be here
Oh yeah, almost forgot! Welcome to the forum.
I sold a 72 GMC SWB last year and it had coil rear suspension.
#13 |
I believe it was 64 when GMC went to leaf springs
66 c-10 swb stepside -my daily driver 74 1Ton CrewCab Shortbed 4X4 (2) 91 2500 suburban 4X4 91 K5 Blazer 4X4-wifes daily driver 73 K5 Blazer 4x4- project soon to be 2wd 50 3 window 3100 |
#14 |
Never Ending Projects
Just to clear this up. Chevy's had coil spring rear suspension Standard and leaf springs Optional. GMC had leaf springs Standard and coil springs Optional. The year ranges from '63 (maybe from '60, I am not sure on the torsion bar frames) to '72. In '73 they all went to leafs in the rear and prior to '60 they were leafs front and rear.
Hope that helps.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#15 |
Senior Enthusiast
My 1960 GMC 1/2 ton short bed came stock with the coil spring/trailing arm rear suspension.
#16 |
I was aware of the earlier and later models not sure on 60-72. Most 61-66 chevys we've had were all coil and the one 65 GMC was leaf all were 1/2 tons 2wd. figures GM would offer the same options mirrored for the trucks. Thanks for the clarification.
