10-11-2010, 10:23 PM | #1 |
Vin #'s, motor swaps, and PO's, now I'm confused
So I've had my '68 for over a year now, It belonged to my grandpa before that. He told me it originally had an inline 6 in it but was swapped sometime before 83 for a 350, according to the code on the passenger side near the water pump the engine is a '75, I'm pretty positive this is correct, also when I replaced the oil pan gasket only the 75+ one would fit So i think that confirms it. Now the vin # on the door jam says its a 68 with a v8, and the SPID also says the same thing, so I just wondering, why would someone change the vin? and I didn't know you could even change the SPID back then anyways, was/is it required that you do that? I live in TX and I'm pretty sure it's always been a Texas truck.
'68 C10 LWB 6.2NA/NP833 3.73's |
10-11-2010, 10:36 PM | #2 |
Old Skool Club
Re: Vin #'s, motor swaps, and PO's, now I'm confused
If the VIN starts out with CS148....., it was a 6-cylinder. If it starts out with CE148....it was a V-8. If the VIN on the door jamb and the VIN on the SPID match, there's a possibility that your grandfather simply forgot what was in it before the engine change.
Age does strange things to our brains and our tongues....I can testify (Can I get an AMEN!) I have said things that I immediately knew were not right, but my mouth said it anyway.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
10-11-2010, 10:41 PM | #3 |
Both vins start out CE1. Yeah i guess that's possible haha although the way he tells it you'd think he was right, I guess it doesn't matter that much just thought it was interesting. Are there any other clues that might point to what motor was original? motor mounts? fuel line sizes? it doesn't have the original gas tank though.
10-11-2010, 10:48 PM | #4 |
Roadtrip!
How close is the dist. to the firewall? That may give us a clue, but not confirm from that.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
10-11-2010, 10:50 PM | #5 |
Old Skool Club
CE1.....it was a 6-cylinder. On the SPID you'll see which engine it had, if it wasn't the base (230) engine. For that matter, it may be that the 250 was the base engine. A 292 was an optional 6-cylinder. But those are the three in-line truck engines for '68.
Sounds like gramps was right. Motor mounts would have to be changed to put the V8 in it. Which engine it had has nothing to do with the gas tank.
10-11-2010, 11:14 PM | #6 | |
10-12-2010, 05:03 AM | #7 |
10-12-2010, 09:21 AM | #8 |
its all about the +6 inches
ce is a v8, period.
off topic, but mentioned above... no 230s in these trucks either. The 250 was the base motor in the inline trucks. |
10-12-2010, 10:50 AM | #9 |
Old Skool Club
My bad on the CE. I mis-typed the E when it should have been an S. When you have a stroke, tell me about how easy it is for you to make mistakes. LonghornMan is right. So was my first reply. A 230 could be had in the 63-66 bodies, and the 250 was an upgrade.I didn't rely on my written data, and did some guessing, which was wrong. As for mounts, the 6-cylinder front mount is underneath the harmonic balancer and mounts the engine to the crossmember. The V8 mounts are on the side, beneath the exhaust manifolds.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 10-12-2010 at 10:54 AM. |
