T5 speed sensor to cable drive
Has anyone ever coverted a manual trans with speed sensor to cable drive. I got a really good deal on T5 but is has a speed sensor. Is there some kind of conversion that can be done or would I need to change the tailshaft housing and internals?
Re: T5 speed sensor to cable drive
would would have to change the ail housing and internals,,,,I went the cheap/easy way and just got a cheap GPS for my truck
Have you removed the speed sensor from the transmission yet? If not, please do so and see if it is gear-driven.
Ray Last edited by raycow; 10-12-2010 at 04:13 AM. |
![]() Join Date: Mar 2010
Try these guys...they will have an answer for u
http://www.speedometersolutions.com/...eter_cable.htm |
#5 | |
Thanks for the link lucifer, I sent them a message, Last edited by enick72; 10-12-2010 at 01:06 PM. |
![]() Join Date: Nov 2007
One solution is a CableX motor drive for the speedo. Works good but not cheap. See the thread below.
http://67-72chevytrucks.com/vboard/s...d.php?t=416110 TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
I agree completely about the Cable-X (price). Unless you need to keep a totally stock dash appearance, you can run an aftermarket electic speedo for less than half the cost.
Ray |
