Old 10-11-2010, 11:40 PM   #1
nikwho
nikwho's Avatar
plumbing in brake lines
So, im ready to start running new brake tubing. What size tubing should i use to go back to the rear axle, 3/16"? 1/4"? its going to feed a 10 bolt w/ drums out of a camaro until I eventually build a 12 bolt with drums.
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 10-12-2010, 12:13 AM   #2
Kim57
Kim57's Avatar
Re: plumbing in brake lines
I used 3/16 on everything.
Kim
Kim57 is offline   Reply With Quote
Old 10-12-2010, 07:58 AM   #3
whid
i used a donor rear end out of a 74 c10....and used the stock style rubber hose.I ran a 1/4" line to the rear rubber hose and then 3/16" to the rear wheel cyclinders....I ran everything else with 3/16"...................whid
whid is offline   Reply With Quote
Old 10-13-2010, 01:36 AM   #4
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I used 3/16 SS on all of mine.
ChuckDriver is offline   Reply With Quote
Old 10-13-2010, 09:40 AM   #5
samdjr74
Same here. It's not that expensive and pretty easy to work with, plus no rust!!!!
samdjr74 is offline   Reply With Quote
Old 10-13-2010, 12:32 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
You can buy nickle/copper line thats very easy to work with and never rusts.
dwcsr is offline   Reply With Quote
Old 10-14-2010, 03:25 PM   #7
robnolimit
robnolimit's Avatar
3/16 is fine, easy-flex is the easiest to work with. Available at NAPA and O'rielly
robnolimit is offline   Reply With Quote
Old 10-14-2010, 08:27 PM   #8
RootBeer 6117
RootBeer 6117's Avatar
Today we replaced the rear brake line on a 1998 2500 dodge 4x4 cummins turbo diesel 200,000 miles,From front to rear axle it was 3/16 steel 11 ft long. Two weeks ago we replaced the rear brake line on a 1997 k1500 4wd ext cab Chevy it was 8 feet of 1/4 inch, it T'd off at the rear axle to the wheel cly,it was 3/16". I have used steel line from parts store for 30 years with out any problem SS will last forever but mild steel will GitRDONE! what ever you use make sure its double flared line DO NOT use compression fittings.
RootBeer 6117 is offline   Reply With Quote
Old 10-14-2010, 10:44 PM   #9
OrrieG
OrrieG's Avatar
I used the line from NAPA too. I looked at stainless but was told it was hard to get good double flares using standard flaring tools. I figure the factory steel lasted 50 years and this set will out live me.
OrrieG is offline   Reply With Quote
Old 10-17-2010, 01:21 PM   #10
52 choptop
52 choptop's Avatar
I just did mine last weekend. I installed a 99 camaro master cylinder with the existing 1/4" lines and still had very weak rear drums, changed to the 3/16 to up the pressure and they work great.
52 choptop is offline   Reply With Quote
Old 10-18-2010, 01:43 PM   #11
Russell Ashley
Russell Ashley's Avatar
I'll give another nod to the NAPA easy flex lines. I just replaced all of the lines on my truck with them and they are easy to work with.
Russell Ashley is offline   Reply With Quote
