Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 10-12-2010, 11:38 AM   #1
F-85
WTB t5 trans
I need a 92 or earlier t5 trans in working order. Let me know what you got.
F-85 is offline   Reply With Quote
Old 10-12-2010, 03:55 PM   #2
70BLAZERX2
Re: WTB t5 trans
I have 4 of them in working order..2 are out of 90 s10's and 1 was a 89 s10 and one is out of a 90 astro van 2.5 All are T5's you just have to run a 83 camaro Z28 clutch disc. 14 spline.
or summit has a direct clutch kit for this swap.
One trans has been used in a 68 350 2wd truck..worked great.Only has to cut 1/4 inch off input shaft (where pilot bushing is) to fit it in the 350 crank
$75 + shipping. each .can go fedex..
70BLAZERX2 is offline   Reply With Quote
Old 10-13-2010, 07:20 PM   #3
F-85
Re: WTB t5 trans
Sounds good. So you know they all work then? Do you know what gear ratios they are? Or do you have the numbers off the trans and i could look it up. How much for shipping to 60542 Lisle,il?
Old 10-14-2010, 10:04 AM   #4
70BLAZERX2
Re: WTB t5 trans
I know these all worked..I drove them all before taking them apart for V8 conversions.
I will check on shipping cost today. have to weigh trans..and see what size box it will be.I will get back to you ,also with pics.
Old 10-15-2010, 01:04 PM   #5
F-85
Re: WTB t5 trans
Cool thanks
Old 10-15-2010, 04:11 PM   #6
70BLAZERX2
Re: WTB t5 trans
fedex is right around $60 to ship trans. PM sent
Old 10-15-2010, 07:25 PM   #7
70BLAZERX2
Re: WTB t5 trans
Here is the pic..I have a 65 chevy car bellhosing bolted to it..
Bell housing doesn't go with it..It should bolt up to truck bell with no mods.
Old 10-16-2010, 09:25 AM   #8
F-85
Re: WTB t5 trans
So these are toploader trans. So Does it come with the shifter too?
Old 10-16-2010, 09:36 AM   #9
70BLAZERX2
Re: WTB t5 trans
yes top loaders..and the astro van one,shifter is farther forward..or i have a camaro tailhousing..that will put shifter all the way at rear...There are alot of options..where the sifter will locate. The camaro T5 is shot..needs 1st gear and cluster gear is bad on 1st also.
I will post more pics too.
Old 10-16-2010, 09:46 AM   #10
F-85
Re: WTB t5 trans
Well its going in a 65 so i dont think the camaro one would fit good. Maybe the asto ones. Just let me know the numbers when you get a chance.
