Old 10-12-2010, 01:00 PM   #1
Triple6Goat
Triple6Goat's Avatar
62' c10 with a 72' c10 rear axle. Driveshaft problems
I have a 62' chevy c10 short bed that I swapped a 72' c10 rear axle into so I could have 5 lugs and do a disc brake conversion. I got new trailing arm saddles welded on so that it will bolt into the truck. The problem I have is I think the U-joint from the 62' driveshaft is to small for the 72' pinion. Does anyone know if a pinion from a 62' axle will fit on a 72' axle or a 72' drive shaft fit in a 62' 3spd. trans?
I would pull the pinion off my old rearend and see if it will fit the 72' axle but I sold my old axle already.
1984 C10 swb
1985 K20 longbed 4spd
1977 K10 longbed -SOLD
1962 Chevrolet C10 swb 6cyl. 3spd. -SOLD
Triple6Goat is offline   Reply With Quote
Old 10-12-2010, 01:10 PM   #2
padresag
Re: 62' c10 with a 72' c10 rear axle. Driveshaft problems
you "think" that it is to small. either it is to small or it isn't. . if they were the same type of rear axle, you could have just changed the yoke, you don't have to change the pinion.
there are conversion joints avail from your auto parts dealer.. if you know the prpoer 72 application they should be able to look it up and tell you what it is and give you the size and then match it to what you have
ron
padresag is offline   Reply With Quote
Old 10-12-2010, 01:32 PM   #3
Triple6Goat
I dont know why i said "think". Would O'reillys or NAPA have these conversion joints?
1984 C10 swb
Old 10-12-2010, 01:41 PM   #4
padresag
"there are conversion joints avail from your auto parts dealer". does napa or o'reillys fall under this category?
ron
Old 10-12-2010, 02:18 PM   #5
Triple6Goat
ron
I was trying to get a more specific answer. Are you always a dick?
1984 C10 swb
Old 10-12-2010, 02:21 PM   #6
padresag
that's right. they are auto part stores are they not
ron
Old 10-12-2010, 02:25 PM   #7
Triple6Goat
your so helpful too
1984 C10 swb
Old 10-12-2010, 03:50 PM   #8
62 Longbed
62 Longbed's Avatar
I wish I had an answer for you on the u-joints , since I have a 62 also .. But I'm also wanting to do the same swap as you ... I shouldn't have to Appoligize for others since were all adults here ... But who yanked his chain , Holy crap ... Good Luck !!!
62 Longbed is offline   Reply With Quote
Old 10-12-2010, 04:30 PM   #9
Triple6Goat
I looked on O'reillys web site for a u-joint for a 72 and a 62 and found that they list some of the same part numbers. I bought one today for a 72 and will test it out when I get home. If it works I will let you know, like I said I didnt investigate it to much when I was under there saturday night. I was more concerned about rearend fitment.
1984 C10 swb
Old 10-12-2010, 05:19 PM   #10
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
go to napa the guys here do this for me all the time...bring the DS and the yoke if you can...if not bring a gift..they can look up the stock u joints for each and get you the proper joint...sometimes its as easy as using the 72 caps on a 66 joint...
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-12-2010, 05:43 PM   #11
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
That's what happens at our store, order the two joints, exchange the caps that you need, return the rest as defect. You pay for 1 joint but use 2 for the parts you need.
Old 10-12-2010, 06:35 PM   #12
LinkbeltOE
Someone in B.C. has a problem, if he's not going to help you he should keep his rat hole shut!!
LinkbeltOE is offline   Reply With Quote
Old 10-12-2010, 06:47 PM   #13
padresag
Hey a/h, I told him exactly what he had to do. you go back and read it and then follow your own advise.
I told him that he needed a conversion joint and to go to his auto parts store and that they should be able to help him
perhaps he still needs his mother to hold his hand
ron
Old 10-12-2010, 06:57 PM   #14
aerotruk63
aerotruk63's Avatar
Alot gets lost in typing something as opposed to talking directly. White flag both sides of the border, were working this out.
"Precision" a manufacturer of universal joints use to give away a Plastic Vernier for this situation. Measure the yokes and give the measurements to ANY AUTO PARTS COUNTER GUY and he should be able to match things up for you. There are books on the different sizes available. I would suggest a store that has been around for awhile, the computer doesn't always help in these situations, Paper Rules!
Old 10-12-2010, 07:14 PM   #15
chevytrucknut61
chevytrucknut61's Avatar
when I replaced my rear end in mine with a 72, the drive fit right in no modifying. I did think I had to get a bigger one but was not necessary.
chevytrucknut61 is offline   Reply With Quote
Old 10-12-2010, 07:59 PM   #16
skysoldier173rd
skysoldier173rd's Avatar
Hey Goat: I actually had a new collar that matched the rear I had put onto the driveshaft i had. They just cut off the old one and weld in a new one. Then you have exactly what fits your new rear. You can then use your existing joint. The collars don't cost that much, think it was around ten or fifteen dollars. Got it all put together, cut welded and balanced and a new joint for around $120.oo at a truck service company. They had all different size collars. Any place that does driveshaft work should have one. Why mess with a conversion joint, for about the same money you probably can have a standard setup.
skysoldier173rd is offline   Reply With Quote
Old 10-12-2010, 08:09 PM   #17
LinkbeltOE
lol
Old 10-13-2010, 04:44 AM   #18
Hottrucks
Hottrucks's Avatar
I got the convertion U joint to go from my stock DS to fit the cadyy th400 yoke for $15 so $$$$$ wise just get the joint and be done with it
Old 10-13-2010, 09:40 AM   #19
Triple6Goat
Ok so I got my u-joint I bought yesterday for a 72' home and matched it up to the rear yoke and its to small. I matched it up to the drive shaft of the 62' and its the same size. I varified online at o'reillys.com that the 62' and 72' take the same u joint.
My guess at this point is that the rearend I have is not from a 72'. The u-joint i would need to fit the rear yoke should be 3-5/16 from cap to cap and the u-joint for the 62' is close to 3-1/16. I need to find a 30 spline yoke that takes a 3-1/16 u-joint or go to a driveshaft shop I guess.
1984 C10 swb
Old 10-13-2010, 12:37 PM   #20
raycow
Where are you measuring those joints? The 62 shaft should take a 1310 joint, which measures about 3-1/4" over the cups. This is the distance inside the lockrings, or between the tabs on the pinion yoke. The cups are 1-1/16" diameter.
I don't have a 72 to measure, but the next larger common joint is a 1330, which measures about 3-5/8" over the cups. The cups on this one are also 1-1/16" diameter.
Please measure the pinion yoke again, and measure it inside the tabs.
Ray
raycow is offline   Reply With Quote
Old 10-13-2010, 03:29 PM   #21
Triple6Goat
Its possible I measered it wrong, and I wrote 16ths instead of 8ths.
But I got it solved, I went to pick-n-pull and found a early 70's chevy c10 and measure the yoke and found it was what I needed with the correct amount of splines.
I guess the axle I got was out of a long bed or something that needed a big drive shaft.
1984 C10 swb
Old 10-13-2010, 06:30 PM   #22
Malibob
Malibob's Avatar
Woops I thought I was on the HAMB for a minute.
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 10-15-2010, 03:26 PM   #23
slepysal
slepysal's Avatar
I thought the same thing
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-16-2010, 01:46 AM   #24
glendale
glendale's Avatar
hell yea! i thought germ bought one of our trucks. btw germ is old school hamb for those that don"t know.
glendale is offline   Reply With Quote
