Old 10-12-2010, 01:37 PM   #1
paintpyro
paintpyro's Avatar
Grafting frame horns
Ok guys, my frame was cut for a rollpan by a PO, just in front of radiator support mounts. I have frame horn sections, going all the way behind the steering box mount area. Where do you think the best place to cut would be? I'll obviously try and reinforce the area, but wondering where the easiest spot would be to line up, and minimize the stress issue on the graft point.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 10-12-2010, 01:46 PM   #2
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Grafting frame horns
tuned in.. I have a short bed frame and the PO did the same thing
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 10-12-2010, 03:35 PM   #3
cdowns
cdowns's Avatar
i'd put on as short a piece as possible to restore frame. there is no need to reinforce the very front of the frame horns as there is no load or stress on that frame section other where the bumper is bolted to it
that's why i always reccomend when clipping the frame horns for rollpan to take the cutoffs and tackweld in the frame channel for future repair to stock
Old 10-12-2010, 03:39 PM   #4
ebfabman
^^^^^^^yup^^^^^^^
can you post some pics....we like pics.........
ebfabman is offline   Reply With Quote
Old 10-12-2010, 03:58 PM   #5
paintpyro
paintpyro's Avatar
Right Earl, like my pics look anything like yours. Posted via Mobile Device
I'll try and snap a few pics when I get home.
"Schleprock"
350 w/TH400
rallys and BFGs
Old 10-13-2010, 11:19 AM   #6
paintpyro
paintpyro's Avatar
pics, based on Earls request.
"Schleprock"
350 w/TH400
rallys and BFGs
Old 10-13-2010, 11:48 AM   #7
scrapmetalart
Junior Member
I would just clean up the cuts on your truck & trim the new horns to fit & weld them on. no need to make extra work.
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 10-13-2010, 12:00 PM   #8
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Grafting frame horns
That is what I would do. The less you cut the less you replace.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-13-2010, 12:04 PM   #9
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
x3
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 10-13-2010, 02:59 PM   #10
MAK191
I had to replace mine also. Here's what I did.
I just removed the rear two rivet heads on the core support bracket on the inside of the frame. Cut the frame in between the rivets. I left the rear rivet shaft in place. Cut the new frame piece to match. the holes lined up perfect and helped line everything up. Then just welded it all back up. Everything looks square and measures up square, but i have not mounted a bumper cause my truck is in pieces.
I chose this method for two reasons:
1. The rivets would help line up the frame horns.
2. The core support bracket will help brace the frame repair.
MAK191 is offline   Reply With Quote
Old 10-13-2010, 03:18 PM   #11
paintpyro
paintpyro's Avatar
MAK, thats kinda what I was thinkin. That would help clean up the frame rail where the PO torched a whole right in front of the radiator support too.
"Schleprock"
350 w/TH400
rallys and BFGs
Old 10-13-2010, 03:54 PM   #12
MAK191
I'm not sure if this is the best way to repair, but it worked for me.
Here is a picture I took during the mock up.
Old 10-13-2010, 07:44 PM   #13
13lazer
13lazers' blazers
13lazer's Avatar
nice bevel, that should make a good weld.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 10-13-2010, 07:49 PM   #14
scrapmetalart
Junior Member
little more work but a very solid way to go for sure
