Lokar Performance Products. Needing some help
We am looking for a section of firewall from a 1967-1970 C-10.
The last time I posted needing a section from a 71-72 the responce was great. If anyone can help with this please contact John Impy at Lokar. Toll Free 1-877469-7440 I can explain what section I need. Thank you John |
Old Skool Club
![]() Join Date: Jun 2001
Re: Lokar Performance Products. Needing some help
Do you mean a picture or the actual physical firewall?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 10-12-2010 at 05:44 PM. |
I need an actual firewall
Old Skool Club
here you go....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
![]() Join Date: Jan 2007
You need everything or just the sheetmetal? If non of the boys up your way can't find one give us a call.
Not having much luck this time. I need only the sheet metal. From inside the truck. I need from just left of the 4 bolts that mount the master cylinder to 24" to the right of that. Should be into the trans hump. From just above tha master cylinder down 24". The area that I am intrusted in is where the throttle pedal mounts and enough area around it to hand some pedals as a referance to each other. Thank you John (865) 966-2269
Old Skool Club
As a purchaser of several Lokar items, including the Eliminator gas pedal, I'm interested in what Lokar has in mind for our trucks. Don't have my gas pedal installed yet, so a new product may be easier to install.
