Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-12-2010, 07:29 PM   #1
baclay9
could I get a little more info on my 454 stuff?
I tore down my 454 today, well it is actually a 468...
It has Speed Pro Hypereutectic Pistons. Part # H581CP They are dome top and have the place where the valves go.
I am putting a set of 781 casting heads on it and was wondering what kind of compression ratio I was going to have? Any help on this is appreciated.
Also the engine has been balanced. Someone told me today I need the harmonic balancer and flywheel that goes with that crank or it will tear my bearings up. Is that true? Are the flywheel and harmonic balancer balanced along with the crank? Because I don't have them.
If you need more info to give me an answer just let me know. Thanks
baclay9 is offline   Reply With Quote
Old 10-12-2010, 08:06 PM   #2
ripdog28
ripdog28's Avatar
Re: could I get a little more info on my 454 stuff?
You really should have the crank balanced with those two. You can run it just putting them on but may not last long. IMO, take it to a shop, have them go through it and rebuild it. A few hundred is cheap insurance.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 10-12-2010, 08:47 PM   #3
baclay9
The harmonic balancer and flywheel that came on my motor are on my dads crate motor he just put in his truck. I guess I should take them back then huh?
Old 10-12-2010, 09:07 PM   #4
baclay9
Any info on the compression ratio?
Old 10-12-2010, 10:06 PM   #5
ripdog28
ripdog28's Avatar
Any work done on the heads? possibly milled the bottom of them so that would change the stock chamber volume. No part # on the pistons makes it impossible to be accurate. If all you have is a short block go ahead and spend the little cash on a tear down and rebuild. even if your changing heads out and its not in a vehicle, get it done.
69 c-10 BBC
Old 10-12-2010, 10:17 PM   #6
baclay9
Piston part # is H581CP. No work done to the heads. They are stock.
Old 10-12-2010, 10:17 PM   #7
chevytruck1970
chevytruck1970's Avatar
if nothing has been milled the speed pro book says 10.2:1.
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 10-12-2010, 10:24 PM   #8
baclay9
That should be fine on pump gas right?
Old 10-12-2010, 10:30 PM   #9
chevytruck1970
with the right cam selection I think it would be fine
Justin
1.35 60ft
Old 10-12-2010, 10:33 PM   #10
baclay9
I am thinking comp cams xe275. Would that be ok or should I go one bigger?
Old 10-12-2010, 10:46 PM   #11
chevytruck1970
thats a good cam you would probably have to have something custom ground to do any better.
Justin
1.35 60ft
Old 10-12-2010, 10:52 PM   #12
baclay9
The motor has a xe268 in it now but I think I will go ahead and step up to the 275.
Old 10-12-2010, 11:20 PM   #13
chevytruck1970
I would with your compression ratio i think it would work a lot better
Justin
1.35 60ft
Old 10-14-2010, 10:48 AM   #14
baclay9
Just as a follow up: I talked to the builder today and he told me I should be fine on the balance. He said if it was going to be hitting high rpm's or going in a race car he would rebalance it. But, I won't be turning over 5500 rpm's probably. He thought I would be just fine. Thanks for your help guys
