10-12-2010, 08:36 PM | #1 |
Door Weatherstrip Install on Fiberglass Top
Hi,
Finally getting my project back together and need some help. Got the top painted and installing all new weatherstrip. Problem is the Single wall top was purchased separate with no original weatherstrip. So I dont have anything to work from and the factory assembly manual only appears to show doublewalls with little detail. Question: How do you mount the weatherstrip around the door windows on a single wall top. Is it just glued in? I see screw holes so was there some sort of metal channel or strip that fit into along the door top glass portion? If so I'm gonna have to try and find some. If someone with a single wall top can take a high resolution picture of how that is mounted (close up please) I would greatly appreciate it. Thanks Darrel Last edited by darrel_s; 10-12-2010 at 08:36 PM. |
10-12-2010, 08:58 PM | #2 |
Re: Door Weatherstrip Install on Fiberglass Top
Yes, there should a metal channel screwed to the top, that the rubber fits into.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
10-13-2010, 11:36 AM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
10-14-2010, 10:55 PM | #4 |
Wow, I learn something new everyday. My top doesn't have those metal channels. Huh??
10-14-2010, 11:42 PM | #5 |
Back in the sticks
May be a single wall only thing. On my double wall, the rubber is held on with adhesive.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
10-17-2010, 04:16 PM | #6 |
Project Junkie! Fishing Poor!!
red71cheyenne is correct. The channel is a single wall top only thing. The double wall tops had holes drilled in the weatherstrip area also, but that was for plastic push-in clips that held the weatherstrip in place. The reproductions do not have the push-in clips, they are designed to glue in. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
10-18-2010, 08:58 AM | #7 | |
2WD Jimmy
