![]() Join Date: Jan 2007
Dual horns, How do I tell if they work?
I found another set of dual horns today and nabbed them. I brought them home and tried to "bench" test them but could not get the High note horn to work. So I thought I would dig up a previous set I found some time ago and again the High note would not work. Which leads me to think that something is not right with the way I did it. I tried several times and several different ways always able to get the regular note horns to work but not the High note horns. Can they both be bad? Is it easy to "burn" one up? I was getting ready to sell the sets but now I am unsure. Help!
Re: Dual horns, How do I tell if they work?
i had one do the same thing ... pecked around on the housing with the handle of a screwdriver and then shook all the dirt dauber nest out of it ... worked great after that.
Thanks...any others?
![]() Join Date: May 2007
I have sprayed WD-40 inside of dead horns before, and they worked fine after that.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
One of the First
![]() Join Date: Jan 2000
Make sure you have two good clean point of contacts on the horn - pos/neg. You can do a continuity check from teminal to horn shell and make sure it is not open. If it is, the coil is burnt. Will not work... Like mentioned above, they get clogged up too.
#6 | |
![]() Join Date: Aug 2012
I bought them from a forum member who indicated they worked before he shipped them. Any suggestions or tricks for me to try to get these working? |
I always just hooked up a plus and minus to the horns to see if they beep
I built it
are dual horns uncommon? my truck has them and ive never thought anything of them, aside from the button on the wheel not working for them..
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
