I was working on my Panel today and noticed that the brake drums were not all the way up against the backing plates so I did some checking. They are all they way against the axels just not backing plates. I called the prior owner. He said he put 70 axles in the factory 64 rear end so he would have 5 bolt axles instead of the factory 6 lug. From reading here I know this is not going to work. Now my question is if I put a complete rearend from a 68-72 Chevy truck will everything line up or will I have to change where the arms mount up? I am hoping it will all line up as I am not no expert welder and dont trust my welding skills enough to weld on the rearend.
"If it throws you back in the seat when it shifts, it was slowing down before it shifted" ![]() ![]() 1992 Chevy 1/2 ton 4x4 wore out 350 1975 Chevy 3/4 ton 4x4/ 8" suspension lift/ 468 Big Block/ 4 speed/ 4.56 gears/ 17' American Racing simulated beadlocks with Pro Comp 37x12.50 tires 1950 Pontiac Chieftain Straight 8/Hydromatic tranny |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 64 Panel rearend question
You're right, that definitely isn't a good situation. I don't know what some people are thinking when doing things like that.
A rear end from a '71 or '72 will be a bolt in swap for 5 lug axles except for the panhard bar. Your '64 originally came with the long panhard bar that attaches to the passenger side axle tube. The '65-'72's attached to the passenger side of the center section. I have changed rear ends to the '65 and up style and just heated the short panhard bar and put a slight bend in it so it will bolt up. Up thru early 1970 all truck rear ends were 6 lug, and are the same width ar your current rear end. The late 1970 rear ends were 1.5" wider, but still 6 lug. Then starting in 1971, they were 5 lug. Of course 1972 was the last year for the trailing arm rear suspension. The easy solution would be to just buy the 5 lug conversion axles for your rear end. However since yours is a '64 you will also need to replace the side spider gears at a cost of about $100.00. Of course this is assuming your rear end is a '63 or '64. So I guess it boils down to what your budget allows.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-13-2010 at 12:39 AM. |
The trailing arms will bolt up, but the panhard bar mount is different. If you don't want to weld, a bolt-on bracket is available from ECE which comes with a custom panhard bar, but it only works right if you are seriously lowered.
If you want to use the stock 65-up setup you will need the later frame bracket, so more welding again. However, it might be possible to bend up a custom bar that will connect the stock 64 bracket to the later axle housing. Ray |
Ok well I can change some spider gears thats no problem...So looks like im buying the conversion axles for my rearend...as i am not welding as i cant trust my welds and the other options I would have to spend to much money by having others do it.....this thing is a money pit....lol...
