406 Powered
Put a 1 wire altenator on the 68 today. What do i need to do now? Was there some wires near the external voltage regulator that i am supposed to cut? Been a while since i did the 70 and can't remember. Red charge light on dash is on.....
70 GMC 68 c10 2002 silverado 72 4x4 |
Back in the sticks
Re: I forgot someone help...please
Shoot, can't remember right off my head. You'll have to pull up the electrical FAQ. There's a jumper for the regulator connector you need to fab up so the light stays off.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Has more rust than truck...
Here is the three wire hook up, not sure if it will help or not.
http://67-72chevytrucks.com/vboard/s...d.php?t=119379 |
Completly disconnect and remove the regulator. You could also just remove the light from the "charge" indicator.
![]() Join Date: May 2007
The little jumper plug you can buy, connects the outer 2 wires together, and the inner 2 wires together.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
406 Powered
Thought i still have to cut the wires and run the jumper though or just remove the bulb?
The whole selling point of a 1 wire alternator is that it uses only 1 wire - so it appeals to people who see themselves as being wiring challenged. However, it has no provision for telling the indicator light that it is charging. You don't have to cut or splice any wires. First, try unplugging the regulator connector. If that doesn't do it, remove the bulb.
Ray |
#8 | |
406 Powered
![]() Join Date: Sep 2010
