stalling, erratic idle
I am having some problems passing smog (running rich) and am wondering if its related to some problems I recently had.
A while back the truck stalled twice on me on my drive home from work. I thought that it could have been b/c I was running low on gas. I made it to the gas station and filled up. When I got home I noticed that the truck was idling erratically - surging up and down. Looking under the hood, I didn't see anything obviously wrong. I thought that it might be a fuel filter. I had to drive the truck to work the next day(only vehicle) and I picked up a fuel filter on the way home. During the time driving the truck, the problem seemed to go away - it didn't stall and the surging stopped happening, so I did not replace the filter. Another thing that I’ve also noticed is that when the truck is cold, it will stall sometimes if I immediately shift into reverse or drive after starting it up. If I let the truck run for 30-60 seconds, it doesn’t do this. Last edited by 70c-10; 10-13-2010 at 12:21 PM. |
Junior Member
Re: stalling, erratic idle
What year truck and what engine and transmission does it have?
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
oops - sorry about that.
It is a 1988 C1500. It has a 700r4 and a 5.7L with an edelbrock MPFI system, heads, cam, headers and fuel pump. |
#4 | |
From your reply to this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=355812 Quote:
Is this thing setting trouble codes? Is it running on a stock ECM & chip? You have headers. Are you running a heated O2 sensor? Stock TBI systems will not tolerate much of a cam. Does it lope, at all, at idle?
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
#5 | |
MPFI - Edelbrock 3502 - Camshaft - Edelbrock 3702 - Headers - Edelbrock 65673 - I think these are the heads, but will have to double check: Edelbrock 60859 Performer Cylinder Head From what I can tell, the truck has passed smog twice since this stuff was installed - when it was sold to the guy I bought it from and when I bought it. Last edited by 70c-10; 10-13-2010 at 11:32 PM. |
I had the coolant temp sensor swapped out and put in a 195* thermostat, also decided to swap out fuel filter since I had it already. I'm still getting similar readings for HC and CO%.
One thing that I did notice after the filter was swapped out is that the trucks starts much quicker. I am reading that the stock chip has to swappped out in order for the truck to pass smog with the edelbrock stuff. I am going to go by the shop today and confirm that the chip was swapped out. Last edited by 70c-10; 10-18-2010 at 02:11 PM. |
i pulled out the ECM this afternoon and it does have the edelbrock chip. i found the postcard that you turn in to get the chip from them, so I was hoping that the chip hadn't been swapped and that was the problem.
![]() I did notice that the exhaust does smell a bit. Not sure what else to try. I thought about swapping out the TPS, but a friend that's a mechanic doesn't think this is the problem. |
#8 | |
With the high CO also it may be dumping in so much fuel that the plugs are covered with soot. All secondary ignition parts should be considered. A mechanical problem like a flat cam lobe, or a cylinder with low compression, is a possibility.
#9 | |
Thanks for the help. The plugs, wires and distributor cap were changed about 6k miles ago, but I will take a look and see if I can find anything. If it's not something simple, I may have to apply for CAP assistance, since the truck qualifies (at least I think it does) and money is tight right now. Last edited by 70c-10; 10-18-2010 at 09:26 PM. |
#10 | |
A called a friend to see if he could come over to listen to the truck run - to see if he thinks the noise I hear is a rocker making noise. I haven't heard back yet, but I hope he'll be able to make it over tomorrow or weds night. Can you determine if you have a dead lifter vs. a flat cam lobe before pulling the engine apart? Last edited by 70c-10; 10-18-2010 at 09:45 PM. |
| Bookmarks |
