Old 10-13-2010, 08:30 PM   #1
TylerHuff
TylerHuff's Avatar
lower control arm shaft need help
alright so i took the upper and lower arms off my 86 dually. i replaced the upper ball joints and painted the arms everything is fine there. On one of the lower arms i can grab the shaft and spin it freely, but i cannot move it side to side. should i just try and tighten it or do i need to rebuild it? i have it all apart and i dont mind rebuilding it so now is the time to do it.
1987 Gmc sierra
1962 Apache 10
TylerHuff is offline   Reply With Quote
Old 10-13-2010, 11:18 PM   #2
raycow
Re: lower control arm shaft need help
If the nuts on the shaft ends are loose or removed, this is normal. If they are tight, you have a problem with the bushings.
Ray
raycow is offline   Reply With Quote
