Old 10-13-2010, 08:51 PM   #1
skysoldier173rd
skysoldier173rd's Avatar
Speedometers
I see several brands of aftermarket speedometers are available. Just wondering how these things work, and if they can be calibrated or adjusted based on a particular transmission or gear ratio. Also are there cable types that can be adjusted to match our mismatched gears, engines and transmission combinations?
skysoldier173rd is offline   Reply With Quote
Old 10-13-2010, 10:04 PM   #2
Big Fenders
Re: Speedometers
I'm putting together a 1960 suburban and the dash console and gauges are to be replaced.In answer to your question it seems that you can buy a mechanical speedo and probably with swapping out 'driven gears' you can just about dial it in or figure out which tooth count gear you need to match your rear end . But after all of that you can buy an electrical gauge that seems to be able to be easily set up electrically to give correct readings. Electrical speedo is about twice the cost of a mechanical one.
Bob
Big Fenders is offline   Reply With Quote
Old 10-14-2010, 12:28 AM   #3
Captainfab
60-66 Nut
Re: Speedometers
An aftermarket mechanical speedo isn't going to be able to be adjustable. You would still need to change the gears in your trans to get the speedo to be accurate.. Some of the electronic speedos are adjustable as Big Fenders said.
Old 10-14-2010, 10:42 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Speedometers
Get a GPS speedo and electric guages. This way you dont have to even care what rear gears or trans speedo gear ya got, just drive the crap out of it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
