Old 10-13-2010, 10:33 PM   #1
67ChevyC10joe
67ChevyC10joe's Avatar
230 to ?? Swap
Is there anything I can swap my 230 6-Cylinder with that won't require me to move the transmission or change the drive shaft? I'm OK with swapping engine mounts but want the cheapest option for now.
67ChevyC10joe is offline   Reply With Quote
Old 10-14-2010, 01:22 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: 230 to ?? Swap
You could take a 350 and lower it into place and mate up to the transmission and then let the engine settle into the frame and drill new holes for the motor mount towers.
That is what I did when I went from a 350 to a 454.
Of course a 350 will need to have a fan shroud.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 10-14-2010, 01:38 PM   #3
DaSchlange
DaSchlange's Avatar
Re: 230 to ?? Swap
Yeah I would say the 350 is about the largest I would go. The 402 may be a little more pain in the butt. In your case, the bigger, the more painful transfer.
DaSchlange is offline   Reply With Quote
Old 10-14-2010, 03:39 PM   #4
raycow
Re: 230 to ?? Swap
You can bolt a SB to your existing 230 mounts and bellhousing and you won't have to move anything else. This was the stock setup on 63-66 trucks.
Ray
raycow is offline   Reply With Quote
