10-14-2010, 12:22 AM | #1 |
Throttle set up help
I am putting a 4 barrel edelbrock carb on my 250 L6. My question is what kind of throttle seat up and gas pedal do I need? Can I use the stock set up? If so how? If not what do you recomend?
10-14-2010, 12:41 AM | #2 |
Re: Throttle set up help
Cable or rod type hookup. What kind of intake. Which way is your carb gonna go. Front to back or sideways!!
10-14-2010, 07:47 AM | #3 |
Currently have the rod set up on the 1 barrel. I'm thinking of switch to a cable. I'm new at this and don't know which would be better. Not sure which way to set carb yet. And I will be getting the Clifford Performance single four barrel intake and shorty headers by weeks end.
10-14-2010, 10:56 AM | #4 |
I think the clifford lets you mount your carb either way and has a heat plate built in. You'll need heat to your manifold or it will run like a dog!!
Here's some pics of mine with a holley 350 2 barrel and Offy intake with Langdon's heat plate and headers. It's on my 65 c10's 230. |
