Old 10-14-2010, 12:43 AM   #1
JimZ
JimZ's Avatar
Parking brake assembly relocation
Tried a search but couldn't get any hits. I have a 65 2wd short bed fleet-side and have installed a 4l80e/ls3. Because of the extra length of the trans, I need to relocate my parking brake cross member assembly, or fabricate something else. Anyone done the same thing? Any after-market kits? Any help, suggestions, plans, photos, appreciated.
JimZ is offline   Reply With Quote
Old 10-14-2010, 01:26 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Parking brake assembly relocation
Post #68 shows Lakeroadster's solution, although this may not help if you're keeping a bench seat:
http://67-72chevytrucks.com/vboard/s...=363509&page=3
Old 10-14-2010, 01:33 AM   #3
dlisabeth
Check out my build thread. I fabricated a new crossmember for my 700r4 and fabbed up a new parking brake assembly by utilizing many of the stock parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=409676
1965 Shortbed stepside Chevrolet C-10
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=409676
dlisabeth is offline   Reply With Quote
Old 10-14-2010, 01:49 AM   #4
JimZ
JimZ's Avatar
I'm keeping the bench seats, so floor mount brake lever is out. I like dlisabeth fabrication idea. Thanks for the responses.
Old 10-14-2010, 04:50 AM   #5
Woogeroo
The other option is the 1966 and later style e-brake system.
Tho', I do not know for sure if it will work on your '62.
I've read/been told the ebrake system was the same from 1960-1965.
I have a '65 c10 and all of the pieces of the ebrake system were gone, so I went with the 1966 and later deal.
some shots of my brakes on my '65.
Poke around on my truck site above, there are some more pics.
Good luck.
-W
update : this article of mine about the 1966 and later style ebrake cable system is now on the forums, here.
Woogeroo is offline   Reply With Quote
Old 10-14-2010, 07:19 AM   #6
robt_virginia
robt_virginia's Avatar
I'm faced with the exact problem. I found this link about installing a pedal brake:
http://www.persh.org/pickup/misc.htm
1962 C10 Sidestep Shortbed
350, 700R4
http://picasaweb.google.com/robtinvi...evyC10Project#
robt_virginia is offline   Reply With Quote
Old 10-14-2010, 09:00 AM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I like that solution if you have buckets.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-02-2012, 03:15 AM   #8
JimZ
JimZ's Avatar
Well it's been almost two years since I posted this question. In the interim, got a lot bigger things done to the project. Finally finished this modification, inpired by your replys. An example of several ways to accomplish the same thing. Like everything else I've done, hope it works.
http://my65short.blogspot.com/
Old 09-02-2012, 08:12 AM   #9
Woogeroo
Ah, so you lowered it down. That's what a lot of folks do, it works good as I understand it!
Very nice work!
-W
Old 06-13-2016, 11:59 AM   #10
JimZ
JimZ's Avatar
Yes, just lowered it. Made it a floating bridge. Solid as a rock and works great.
