Old 10-14-2010, 02:14 PM   #1
72chevyk10
I built it
72chevyk10's Avatar
steering is sloppy
so yesterday, i was driving my truck and it seemed diffrent to me. the steering wasnt as responsive as usual. and as i drove it more, going straight down the road the wheel was upside down. so today im gonna see about tightening up the steering gear box (power steering). anything else i should look for? im sure the box needs replaced but i dont have the money at the moment.. just tryin to get as much out of it as i can
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 10-14-2010, 03:10 PM   #2
chisler
chisler's Avatar
Re: steering is sloppy
Give this guy a call as its not to far away ...I did a steering box exchange for $225 plus tax www.steeringsolutions.com this guy is good, knows his stuff and has them in stock good to go
chisler is offline   Reply With Quote
Old 10-14-2010, 03:11 PM   #3
72chevyk10
I built it
72chevyk10's Avatar
never mind, i found the problem. and i feel kinda stupid the bolts holding the axle to the spring on the driver side had worked loose some, and the axle was slideing a bit. im just really confused how they would work loose??
Old 10-14-2010, 03:13 PM   #4
72chevyk10
I built it
72chevyk10's Avatar
thank you for the link, but i found out what was wrong
Old 10-14-2010, 03:20 PM   #5
chisler
chisler's Avatar
No problem...but down the road if you need to replace/rebuild your steering box this guy is good and honest, good that ya had a cheap fix this time!!!
Old 10-14-2010, 04:36 PM   #6
Wrenchbender Ret
Better check the spring center bolt. It is probably sheered off. This is what centers the spring to the axle.
Wrenchbender Ret is offline   Reply With Quote
Old 10-14-2010, 10:07 PM   #7
72chevyk10
I built it
72chevyk10's Avatar
ok good to know thank you
yea, that was the first thing i checked, its still intact. its just the nuts holding the u-bolts had worked loose somehow..
Old 10-14-2010, 11:17 PM   #8
Dark Knight
Dark Knight's Avatar
red lock-tite, lock washers, and double nut it, using a Teflon nut on the top. Then they MAY not back off again. lol. As you can tell, I over-engineer everything.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 10-14-2010, 11:58 PM   #9
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Glad to hear you got it fixed, I read this earlier today and thought it strange that all of a sudden the steering would get sloppy.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
