Old 10-14-2010, 05:25 PM   #1
hawksnest116
Angry fuel issue
Does anyone know what to do next? 1984 GMC half ton. Two wheel drive long box. I cant switch fuel tanks. I started easy and replaced the switch. Then I replaced the fuel selector valve under the cab. I still cant switch tanks. I took the switch back off and it turns out its not getting power. Is it suppose too? Also took the dash apart to fallow the wires. It turns out that as I fallow it back to the fuse box there is a thick pink wire that runs directly into the fuse box is this right? I am starting to get frusterated any ideas or help?
hawksnest116 is offline   Reply With Quote
