Old 10-14-2010, 06:29 PM   #1
RIA69
RIA69's Avatar
350 heads on a 307?
I have a 307 that needs heads on it and I have some off of a '71 350 the casting is 3932441 these are the stats for them
76 CC Chambers
Intake flow 152 CFM
Exhaust flow 93.2 CFM
and valves
1.94/1.50
I will be running a 280h comp cam with a weiand intake and a eddy 4bbl 600 cfm carb. my question is will I run into any issues with compression or anything? I know 307s are the "red headed step child and all but I like it.
I will also be running flow tech headers with cherry bomb glass packs straight off the headers.
thanks in advance.
1969 C20 3/4
ΜΟΛΩΝ ΛΑΒΕ
RIA69 is offline   Reply With Quote
Old 10-14-2010, 08:09 PM   #2
71 super
71 super's Avatar
Re: 350 heads on a 307?
Cam is going to be lumpy and you are not going to be very happy with that combo. If you are running a manual you will be a little better off, but if heads are stock (no port /polish) and an automatic with a 3.07 gear it is going to be a dog. That cam is going to want to run around 2800 or more to begin to make power and your motor in stock form will run out around 4000, never reaching the potential of the cam. You need to match your parts better to get the most out of the setup you are going to run.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 10-14-2010, 08:31 PM   #3
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Thats what i was thinking.
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 10-14-2010, 09:15 PM   #4
RIA69
RIA69's Avatar
ya I can understand that but at this time this is all I have at my disposal. Im in the middle of a divorce and this truck is supposed to be my daily so I have to try to get it running before the future ex takes the good running car. the tranny is a 4 speed manual, still not to sure of what it is though. I know its a granny geared one. I have a 350 that I took the cam and heads off of, but its so nasty inside it will take me months to clean it up, I just dont have to much time this set up im thinking will only be temparary. once taxes hit then Im going to rebuild the 350 and port and polish the heads and do a mild build up but for now this is what Im stuck with. I think the rear end is 4.10's or something its a torq monster. thanks for the input though its helped. would it even be worth messing with? I dont want to run this combo if its going to destroy the parts.
1969 C20 3/4
ΜΟΛΩΝ ΛΑΒΕ
Old 10-14-2010, 10:30 PM   #5
71 super
71 super's Avatar
It will not destroy parts, but you mileage will not be the greatest. Sorry to hear about the divorce. I hope that everything works out. If you could find a set of 305 heads and a 265 or 270 cam the truck would like it better. The 305 heads have a smaller combustion chamber and increase the compression quite a bit, and since you have the 280 cam, this will help to bleed off some pressure so it will run on pump gas. The increase in compression will wake up the 307 some. If you have a 4.10 gear you will get away with a little bigger than the normal cam simply due to mechanical advantage created by the gear and trans combo. If it is a 3.73 you will lose some advantage. Summit did have a cam line that had a really good selection that would better match the parts you already have on the cheap. I ran one in a 327 I had a couple of years back and it would flat out roast the tires with a 3.73 gear. Seems like the lift was .465 and .470 dual pattern for less than $80, this was with a performer rpm, hei, headers and 600 holley- nothing special just parts that matched up. Good luck with your project and have fun with it.
Old 10-16-2010, 07:22 AM   #6
jim zag
ENGINE BUILDER
jim zag's Avatar
Low compression and a big camshaft. You will not be happy. A better choice would be a set of 305 4 Barrel heads and a cam that is less than 220 degrees @ .050 duration. This will give you more pumping compression and way better driveability.
JIM ZAG
jim zag is offline   Reply With Quote
Old 10-16-2010, 07:48 AM   #7
You just need from a stock to RV-type cam.The heads aren't an issue at all.
Old 10-16-2010, 12:38 PM   #8
raycow
It's not the best combination because of the low CR. Please reconsider about the cam unless it is already installed in the engine. The good news is that the manual transmission will somewhat make up for the lack of low-end grunt, so it won't be as bad as it would have been with an automatic.
Ray
raycow is offline   Reply With Quote
Old 10-16-2010, 12:43 PM   #9
WIDESIDE72
WIDESIDE72's Avatar
I think you would be happier with a store brand cam, Speed Pro, or one of the bare bones cams. Too much cam and not enough cubic inches or compression. I know from experience about overcamming an engine. A 280 is too much even for a DD 350 with 10:1+ comp. Go stock if you have to. It will actually run better and give better mileage.
WIDESIDE72 is offline   Reply With Quote
Old 10-16-2010, 05:07 PM   #10
RIA69
RIA69's Avatar
thats what I would like to do and plan on doing once I have some money to use on it. I have been looking for a set of 305 heads for my 350 I am building up to replace the 307and I am thinking of just going with a 260 cam or something for it. the previous cam that I had in the 307 which i still have is the reason the motor got tore down in the first place has 4 flat lobes which I didnt know until I drove it 1200 mile from utah to kansas. not a fun drive by the way. thanks again guys.
1969 C20 3/4
ΜΟΛΩΝ ΛΑΒΕ
Old 10-16-2010, 05:53 PM   #11
RUSHNBOBO
When u build a motor all the parts need to match and compliment each other in your desired rpm range ......
The variables are endless ..tens of thousands of combos just for a street SBC.
That being said here's my fav drivable street 350 combo...that i run in my daully......also low buck and makes (around 350-375 H.P.)
A. flatop pistons (I run forged speed pro but cast will work up to 5500 rpm) and 64cc heads camelback ...gives around 9.7:1 to 10:1 compression
B. Cam: Comp XE268...nice lope very driveable and largest cam that will work with a stock converter ...although i run a slightly higher stall in mine.
(more than 1 magazine test calls this the best all around street cam on the market...power to 5800 rpm!!!)
C. 1 5/8 long tube headers ...1 3/4 gives slightly better top end numbers but low end torque is lower
D. Performer rpm manifold ....i prefer the older style without the air gap due to the cut down plenum divider....which affects snappy off idle response due to a poorer signal at low rpm (velocity)....off idle they show nearly identical numbers to 6500 rpm. The benefits of the air gap though do come into play only on fully warmed up engine after heat soak sets in .....how much? probably not enough to justify the much higher price tag. IMO
E. DO NOT USE A CARB LARGER THAN 650 CFM on a street 350 ...every dyno chart ive seen there's no high rpm power gain and often a loss at low rpm.
A mild 350 simply cannot use any more carb
Remember this when build any street motor .......................................
"A little to small always beats a little to big" (except cubic inches of course)
My girlfriend though thinks just the opposite.....ummmmmmm
RUSHNBOBO is offline   Reply With Quote
Old 10-19-2010, 03:16 PM   #12
ffk
ffk's Avatar
hey i have a set of heads off a 68 307 motor...there still on the complete motor...just sitting here..love to sell complete or ill sell the heads
ffk is offline   Reply With Quote
Old 10-19-2010, 03:44 PM   #13
w3lfd
You are basically spelling out exactly what the PO of my truck did and it runs like a big fat turd, even with a manual transmission.
I am "upgrading" to #416 305 HO heads (got them for 95 bucks shipped) just to get away from this set up.
305 Heads are CHEAPCHEAPCHEAP. If money is an object I would seriously go this route rather than the 350 head.
The 350 / 400 heads actually bring compression way down on the 307. My fuel consumption is through the roof (this may or may not be directly related to feeling the need to floor this POS to make it move). You would probably be better off saving the gas money up by limping on the motor you have and then buying decent upgrade parts.
Seriously. Think 8 MPG. Just think about it.
w3lfd is offline   Reply With Quote
Old 10-19-2010, 05:18 PM   #14
'72customdeluxe
305 heads aren't recommended for performance usually these days, but a vortec would have your compression pretty low aswell. You could get some 601 (305 ho) or atleast 416 (305 4-barrel) heads remanufactured off of ebay cheap. Here are some -601's that have been rebuilt and they claim 52cc chambers
http://cgi.ebay.com/ebaymotors/SB-SB...Q5fAccessories Not only will the 305 ho heads keep you from dropping to unacceptably low compression levels, but the chambers are better looking and ports should be better. I would run something like a 204/214 (summit-rebox, lunati, everyone makes them) for a cam
'72customdeluxe is offline   Reply With Quote
