10-14-2010, 09:20 PM | #1 |
impala steering wheel.
i saw i a cool c10 swb wth a 61 impala steering wheel in it thought that was pretty trick will these bolt right up??? i wanna do a 58-61 impala steering wheelin my 69 c10 there are two or three dif styles just curious if any one knows if they would work? if not im gonna do a 3 spoke wood grain from lmc or summit. any input would be greatly appreciated.
10-15-2010, 01:37 PM | #2 |
Re: impala steering wheel.
I would imagine the impala steering wheel will work. I am running a 65 nova steering wheel and it bolted right on. The diameter of the hub and column were even the same, it was magic! but ya I believe itll work
11-06-2010, 03:31 PM | #3 |
hey update i think i am gonna run a 66 bel air steering wheel i found one for 40 bucks i really wanted a 60's caddilac steering wheel but they are kinda spendy! what paint did you use on yours?
11-11-2010, 11:36 AM | #4 | |
i think they changed the columns in 67 or 68. it will work on the earlier columns. if i'm wrong someone please correct me. |
11-12-2010, 02:17 PM | #5 |
yeah im banking on you being wrong lol..its a 66 impala steering wheel i ended up buying and mcClinton swapped in a 65 nova steering which actually looks very much the same as mine and he had no problems at all so im hoping that it works out, we will find out on saturday! ill post pics of it working or the issue with it not working!
11-12-2010, 05:46 PM | #6 |
Subscribed.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
11-12-2010, 10:18 PM | #7 |
also subscribing , any pics?
11-12-2010, 10:26 PM | #8 | |
11-13-2010, 04:22 PM | #9 |
Also subcribed
11-13-2010, 04:35 PM | #10 |
Theres a truck in the December 10 issue of STREET TRUCKS with the Impala wheel....just saw it, looks sweet!
11-13-2010, 07:21 PM | #11 |
hey guys its gonna be a couple days i bought the steering wheel from ebay but its a local scrap yard a hour away so i was going to pick it up but i gotta watch the Oregon Duck game go ducks! so im having them ship it to me should be here next week sorry!
11-13-2010, 07:25 PM | #12 |
if the steering wheel does not work, couldnt i just grab a 67 column and swap it over as well?
11-18-2010, 01:54 AM | #13 |
just received my 66 bel air steering wheel today in the mail cleaned up the horn ring im going to try and put it in tomarra ill take pics and should have stuff on here in the next couple of days!
11-18-2010, 07:54 AM | #14 |
It'll fit.
11-21-2010, 08:44 PM | #15 | |
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
11-21-2010, 10:49 PM | #16 |
Old Skool Club
The late 50's and early 60's steering wheels were clean. I can't believe there's only one pic after 14 posts...
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
11-23-2010, 12:20 AM | #17 |
My truck was originally a big back window 67 long bed. It had a three on the tree column though so I swapped it to an auto from a local salvage yard. I believe the column is newer for sure. Anyway all the same I believe regardless you can make the wheel work
Posted via Mobile Device |
11-23-2010, 10:05 PM | #18 |
hey guys sorry about the wait but the wheel did WORK it was a breeeezzz!
heres the steps and stuff that you would need along the way my truck is actually a late 69 so its a 70 model year. but the steering wheel is off of a 1966 chevrolet belair. enjoy! Last edited by buttrock slp ss; 11-23-2010 at 11:01 PM. |
11-23-2010, 10:09 PM | #19 |
here is the pre paint wheel kinda a cool sea foam color i scuffed the wheel and paint chips flush with 180 grit sand paper and its important to tape front and rear center hub becaus this is a contact for the horn mechinisim. i shot it with primer then 3 coats of matt black i may do cream or gloss soon imnot sure yet, i cleaned the chrome horn ring with very fine steel wool and ol tooth brush and chrome cleaner
11-23-2010, 11:30 PM | #20 |
heres the puller you will need to pull your steering wheel. you will need 3 longer bolts to screw into the steering wheel to hold the puller. This one had a 1/2 size end to turn to push the center spline and pull the steering wheel off the splines. i used my 3/8ths electric impact..dumb idea its too fast and i messed up the threads because it set the puller of center and pushed out the corner of the threads also use a flat extension on the end that is going to push on the center spline i used a pointed one and it made thoose divits in the spline center you see in the pics.. .. i used my 3/8ths long handle ratchet instead and it pulled off just fine. i used a 12x20 die to clean up the threads when i installed the nut. people say to buy a new nut but it looked and was fine i just used some locktite blue and reinstalled it. #1 DISCONNECT THE BATTERY NEGATIVE CABLE. if you dont you will be sparking and honking the horn any time you touch the horn contact or wheel hub when its installed..
11-23-2010, 11:39 PM | #21 |
the center contact piece you will need to reuse here is what i had with the 66 belair i bought. i used the horn ring bolts and plastic insulator spacers cause they where in better condition then the ones on the truck
you will need to keep the thin metal contact disc and this faces flat side down and the three prongs facing up on the steering wheel from the bel air. you will not need the contact pin and plastic shaft piece that was from the old wheel. . heres the old wheel contact ring on the right and the new old belair style you will reuse on the left. Last edited by buttrock slp ss; 11-24-2010 at 12:04 AM. |
11-23-2010, 11:44 PM | #22 |
now MAKE SURE BEFORE YOU PULL THE WHEEL YOUR WHEELS ARE STRAIGHT LOL!
with the old wheel off i installed the new old wheel onto the splines it slid right on. The horn contact pin slides up through a hole through the steering wheel. Last edited by buttrock slp ss; 11-24-2010 at 12:04 AM. |
11-23-2010, 11:49 PM | #23 |
i then installed the thin contact disc 3 prongs facing up and line up the holes with the holes on the steering wheel then install the plastic insulator ring and bolt up the horn ring with the horn ring bolts.
11-23-2010, 11:58 PM | #24 |
TILT COLUMN GURU
Here's what's turning "Crooked" for now.
64 Impala bolted right up
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
11-23-2010, 11:59 PM | #25 |
after the horn ring is installed i re tapped the threads on the center hub and put blue locktite on the threads and tightend the center hub nut pretty tight dont kill it just make sure its plenty tight. i then installed the horn cap and then your done i have no clearance issues and the wheel although abit bigger than my old one looks awesome.
