Old 12-19-2001, 01:52 PM   #1
big rig duallie
Post 6.2L Diesel swap into 69' 1 Ton Duallie?
I'd like to swap in a 6.2L diesel once the old small block dies. Will a 6.2L fit up to a ch465 four speed? Also would motor mounts from a diesel of the year the motor was made fit into a stock 69' Chevy chassis? Other than that, everything else is small work. I know it needs a vacuum pump because diesels don't create their own vacuum. I don't wan't to run a computer, so I'll hook up the accelerator pedal directly up to the injection pump. Does anyone know of aftermarket accessories like cams, intakes, and headers? This would be a good swap , but if anyone knows and can help, drop me some info. Thanks
69' 1 Ton Duallie
big rig duallie is offline   Reply With Quote
Old 12-19-2001, 09:27 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
moving to 67-72 board
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
