Truck won't shift
I recently pulled the engine to change the flex plate. See thread: http://67-72chevytrucks.com/vboard/s...d.php?t=425605
Got everything put back together, and it's running fine, but I started to go to work and the transmission's not shifting. It'll go into reverse, drive, neutral, park, but when driving it won't shift out of first. What controlls the shifting, and what could I have messed up that would be causing this? I was so excited that I finished the job and now it seems I didn't do as good as I thought. |
Re: Truck won't shift
Check the vacuum line that goes to your modulator on the transmission. No vacuum makes it think you are at wide open throttle so it holds first.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
is there any way you could show me a picture or diagram or something, or describe where it hooks up to what? I'm about the farthest thing from a mechanic that there is. I'm just driven into it by poverty and desperation.
a fool with no money
![]() line goes from here to carb...
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
Good deal - beat me to it. So it's a hard line with rubber ends on it, goes from the nipple pointed towards the back of the truck (that is a th350, not sure which trans you have) and runs up to the back of the intake where it either plugs into the intake or the carb. Good luck, and nice work with the R&R on the flywheel!
Thank you very much. Just came out from under the truck, and sure enough, that hose was popped off the nipple. Forgot to pull that line when I pulled the engine and it got stretched a little tight before I noticed it an disconnected it. Can't test it yet, wife's left me with 3 kids this morning (speaking of which, how hard would it be to put 4 seatbelts across the bench instead of 3?), but I should be able to get out there within a few hours and check. Pretty confident that's the problem though.
Don't do it seat belts are a fed. safety law.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
Oh that's crap. I want to take my wife and two kids out boating without bringing the second car. Oh well.
Took it out for a spin and it shifts great. No more problems! Thanks! |
Insert Witty Text Here
Don't feel bad. I did the same thing he second time I pulled my trans out. By then I should have known better.
![]() Glad to hear you got everything working. Slonaker |
