Old 02-28-2003, 02:51 PM   #1
low 84
low 84's Avatar
10 & 12 bolt u-joint the same?
if i'm swapping from an '84 10 bolt to a '75 12 bolt, is the rear u joint the same? so will it bolt right up, or do i need a different u joint? i know perches and width ect are all the same so it will fit right in just not sure bout hookin the driveshaft up.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-28-2003, 03:17 PM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
I believe it is different.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 02-28-2003, 03:17 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Unless you use the 12 bolt drive shaft you need a different u-joint. Part number 372 Spicer from Napa if I remember correctly. The caps for both are different sizes. To convert to the 12 bolt, you need a joint with two large caps and two small caps. I know, I destroyed one already and replaced it with the Spicer. The spicer U joints seems to be tighter too.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-28-2003, 04:30 PM   #4
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
The 12 bolt originally used a 1310 ujoint, the 10 bolt originally used a 3R ujoint. I have a 3R yoke for the 12 bolt that I put in my 84, not installed yet, but it will allow me to have a 12 bolt and the larger 3R ujoint which will also be the same as the front ujoint in the rear shaft and a little easier to find if one breaks on the road.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 02-28-2003, 10:03 PM   #5
low 84
low 84's Avatar
so i will need to use the two larger caps off the 12 bolt and a u joint for a 12 bolt, correct? anything else i need?
'05 1500 Crew Cab
RIP
Old 02-28-2003, 10:39 PM   #6
BaggedC10
Under construction!
BaggedC10's Avatar
My 12-bolt rear-end has the same yoke from my factory 10-bolt unit.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
