Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-15-2010, 03:58 PM   #1
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
dual electric fans....2 relays or 1?
got my dual 16" fans mounted and im ready to start wiring them up. i will be using a temp switch in the drivers side head to provide a ground. do i need 2 relays?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 10-15-2010, 04:21 PM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: dual electric fans....2 relays or 1?
I would use a relay per fan. It sucks big time when your wiring or relay melts down on a trip. Been there done that.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-15-2010, 04:25 PM   #3
vasquezmrysvll
"the other guy"
does that mean use 2 temp switches too or would 1 provide sufficient ground for 2 relays? thanks
Old 10-15-2010, 04:40 PM   #4
Dieselwrencher
I used one temp switch on one, and then I hooked the other in line with the a/c clutch so it would come on when the a/c is on. I also hooked the 2nd fan in to a wire that I can toggle in the cab that allows the 2 fans to work as one through the 2 relays that way if I was towing and the a/c wasn't on I could still have 2 fans.
Ryan
Old 10-15-2010, 06:34 PM   #5
cparman
sharp as a marble
Yes, like Dieselw said. I just installed a dual 11" fan setup in a customers car, and used all SPAL fan stuff. Dual fans, and their PWM fan controller. Worked great. The controller works like one relay, and their instructions said to use an additional relay to power the other fan. The controller is programmable for you to set turn on and turn off temps, using one temp switch. If you go to their site and click on the PWM, there will be a download with instructions to install. They also recommend a toggle switch for an override, just in case of a failure. I spoke to them when I had a couple of questions, and they were very helpful in helping me understand their product. I would use this setup again.
cparman is offline   Reply With Quote
Old 10-15-2010, 06:37 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a diagram. It only has one fan but the second one would be easy to add and I would run a second relay also. That way you would have a back-up in case one failed. Where are you mounting the temperature gauge sender?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-15-2010, 06:52 PM   #7
vasquezmrysvll
"the other guy"
either drivers head or drivers side intake passage
Old 10-18-2010, 09:34 PM   #8
tqlspec
tqlspec's Avatar
...and keep a spare relay or 2 in the glove box. Cheap insurance when a relay goes bad.
Retired Navy
1972 C10 Cheyenne fleetside
350 sbc, 700r4, 3.42 rear
tqlspec is offline   Reply With Quote
