10-15-2010, 09:22 PM | #1 |
Rear hatch
Does anyone know of a method on how to remove the rear hatch (those two rusty hinge bolts)?
10-15-2010, 10:47 PM | #2 |
Back in the sticks
Re: Rear hatch
Are you talking about the hinges on top or the support arms on the sides? I had to drill out all of the side arms, but the top hinges came out ok.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
10-16-2010, 08:42 PM | #3 |
Re: Rear hatch
The hinges on top. I've used a punch to try and pop them out but they're not giving up without a fight!
10-16-2010, 08:51 PM | #4 |
Back in the sticks
Re: Rear hatch
Oh ya, I couldn't get the pins out of mine either, so I just soaked them in PB Blaster for a few days. Now they work fine.
10-17-2010, 08:51 AM | #5 |
GEARHEAD
Re: Rear hatch
If your just trying to remove the hatch, take the metal covers off that cover the bolts into the top. Remove the bolts and pull the hatch out with the hinges on it. Then you remove the bolt covers on the hatch and take out thos bolts and you can pull the hinges out. Now you can put the hinges in a vise or press to remove the hinge pins.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
10-17-2010, 03:44 PM | #6 |
Re: Rear hatch
Thank you for the input. Just wanted to make sure I was headed in the right direction in the removal process
10-17-2010, 08:41 PM | #7 |
Back in the sticks
Re: Rear hatch
My bad. I thought you already had them out of the top and hatch.
10-19-2010, 10:21 AM | #8 |
Re: Rear hatch
Yeah, I have always done it like HGS_notes stated. I have run into issues with the little screws that hold the cover plates on though, as they like to strip, but they drill out easily. I had to use a lot of brute force to get the rusty hinge bolts out of the latest hatch I grabbed, and it helped to try and loosen them all up at the same time so the last one doesn't try and turn the hinge.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
