motor noise
i think i have a bad lifter or it just not adjusted right. i have a 327 sbc in my 61. the heads are rebuild and i have a new cam and lifters and the bottom end is rebuild with under 500 miles on it. the cam and lifter have less then two tanks of gas on them.
so when i start it up i have a really quiet noise its a ticking sound and when it gets warm up its gets a little louder. it never really loud. but its still there. what does it sound like to you. |
Resistance is Futile
Re: motor noise
Maybe it's an exhaust leak??
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Re: motor noise
Loose arm?
Re: motor noise
arm?? what arm??
Re: motor noise
i put my hand around the exhast and i don't feel n e thing.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: motor noise
Did you use a good breakin oil additive when you started the engine and ran the cam breakin? Are you running a oil that has sufficient ZDDP for flat tappet cams? If you're not sure what I'm talking about, take some time to read here.....http://www.67-72chevytrucks.com/vboa...d.php?t=381780
If you adjust the valve lash again, and it comes back, it is possible that a rocker stud is working loose. It is not uncommon for this to happen to rebuilt heads that retain the pressed in studs. It seems that if the heads got a little too hot during the cleaning process, that expands the casting around the studs. This can be checked by putting a straight edge on top of all the rocker studs. They should all be the same height. I found this out the hard way after several hours of greif.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-16-2010 at 12:28 AM. |
60-66 Nut
Re: motor noise
Intentionally Left Blank
Re: motor noise
Take a piece of rubber hose about 1/2" in diameter and about 2 feet long, put one end to your ear and move the other end around the engine where you think the noise is coming from. This works like a doctors stethescope, and will narrow the location of the noise down considerably.
A noise that gets louder when the engine is warm could be several things. A lifter that is bleeding off oil pressure too soon as the oil gets warmer(thinner). A gasket leak that is opening wider as the two surfaces are expanding when the engine gets warmer. Hopefully it's just a rocker arm out of adjustment. As the oil gets thinner the noise will become a little louder.--Keep us posted, Jeff.
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
