Pic request: LED tail light, back/plug side
I'm going with a Blazer tank and have decided I want my fuel filler behind the tail light. I like the side marker light filler door too, but with the big vapor traps on the gas pumps these days, I think the tail light will work out better. I will hinge at the bottom and am thinking about going with LED's to clear up as much room behind the lens as possible. I was wondering is anyone has gone with the LED conversions that are on the back cover of the current (2010 Fall Edition, CB.61) LMC catalog, part #37-0341. These are also sold by Brothers, part #LED72F0. These are the ones that retail at both places for about $50 each. It looks like these just plug in like a bulb, but I am more curious about the shape and depth of the actual assembly. If anyone has these and can snap a side and rear view of them, it would be greatly appreciated!
While I am on the subject, if anyone has also used the LED taillight conversion kit that uses the stock lens (LMC part#37-0342), a picture of the same thing as above would be great. Thanks in advance!
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" |
Its a Truck Thing......
Re: Pic request: LED tail light, back/plug side
The 0341's fit nice in the housings, I am running them.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Does that mean that they don't save any room behind the housing (using the stock one), or are they actually shallower? Any pictures? Many thanks...
i'd also like to see a pic of them while lit up
I didnt need a flasher with the LMC ones...
Smitty
Old member
These LED'S are the ones I bought from ECP. They are made by a board member. They have the 1157 pigtail that just plugs into the socket. Been in the truck for 5 or 6 years now.
This was with the clear lens, I have since gone back to the red lens. Safety first. Night time shot with all three lit up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Any uninstalled pictures for those that already have the LED's?
Old member
My LED'S fit between the housing and lens with no mods what so ever. Sorry didn't know you wanted internal shots. I'll see what I can do. Sorry they are side ways.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 10-18-2010 at 05:28 PM. |
Thanks for those shots. It looks like that these lights won't create any more room for a fuel filler since they retain the stock housings, although I guess I could cut those if necessary.
