core support install
on a 69-72 truck, to install the core support....what order does the new bushing set go? Need to what order the rubbers and hardware go?
![]() Join Date: Aug 2008
Re: core support install
from memory, drop the bolt with square waser in from the top of the support, big round donut rubber under support, set on frame, then big tapered rubber, big flat washer then nut
This might help. Go to lmc trucks catalog and on page 32, item 8 thru 14 shows the order in which to put them. Hope this helps.
#4 | |
thanks fellas.....that helps a lot. Hopefully I can get to the point to put the core support on. LOL
