Old 10-16-2010, 02:14 PM   #1
DrtyJack75
Date stamped on frame? & What rear end is this?
So my truck is stripped down now and yesterday while priming it, I see
3887701-200
9-12-79
Is that the year the frame was built?
Because if it is, I'm now learning my 67 is not sitting on a 67 frame.
I was also cleaning up the rear end and was wondering if you can tell me what gears are in here (or were when built)
This is on the axle tube
HA 09 27 W
G86 (hard to read) is on the rear end housing
Does that help?
DrtyJack75 is offline   Reply With Quote
Old 10-17-2010, 05:40 PM   #2
DrtyJack75
Re: Date stamped on frame? & What rear end is this?
No one??
Is it a dumb question? LOL
Old 10-17-2010, 05:48 PM   #3
john
member #16
john's Avatar
HA shows for several years with 1969 the latest. 3.73:1 ratio It is listed for a 1967 C-10
john is offline   Reply With Quote
Old 10-17-2010, 06:02 PM   #4
DrtyJack75
awesome...thanks
now how bout the year on the frame??
Help please, Im curious if this is a newer frame
Old 10-17-2010, 06:25 PM   #5
Shaky
Six in a row makes it go...
Shaky's Avatar
I'm not sure the "79" means "1979". My '67 C20 frame has a "69" in that same location and I'm pretty sure it's the original frame. I don't know for sure though...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 10-17-2010, 07:00 PM   #6
DrtyJack75
hmm it's just weird.
were the 67's power steering?
mine has power steering which dont mean it wasnt added, but it does have little raised nipples where the power steering box is mounted.
Old 10-18-2010, 07:52 PM   #7
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Id love to know if there is a way to decode this info too. My 68 has a 72 in that location. Searching hasnt turned up anything.
dutchmanz is offline   Reply With Quote
Old 10-19-2010, 05:56 PM   #8
raycow
Do you have disc brakes? Do you have leaf or coil springs?. No stock 79 would have front drums or rear coils. None of this is bulletproof because a stock 67 could have leaf springs, and disc brakes are a common upgrade.
Ray
raycow is offline   Reply With Quote
Old 10-19-2010, 08:00 PM   #9
DrtyJack75
drums and coils when I bought it..
so I dont know....I guess it dont matter, just curious!
now Disk and Bags...
Old 10-19-2010, 08:24 PM   #10
raycow
My bad. I meant no stock 79 would have front drums, so I'm guessing you have an original frame. Sorry about the mistake. I will fix that right now.
Ray
