![]() Join Date: Aug 2010
Neutral safety switch..Please HELP
The PO removed the neutral safety switch / back-up light switch on my column. I am trying to install a new one, but the switching tangs hanging out the bottom of the switch are not long enough to reach the indent in the column. Am I missing something? Is there another piece that links the 2?
67 5.3L Build |
454 MAKES IT ROAR
Re: Neutral safety switch..Please HELP
Yes there is a small tang that should be attached to the inner column the black plastic tang on the bottom of your NSS hooks upwith that.
I made one up for mine...... ![]()
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 10-16-2010 at 04:56 PM. |
member #16
![]() Join Date: Dec 1999
If you have a converted van tilt column it will use a different switch than a truck column. No tang to fit on.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 10-16-2010 at 04:58 PM. |
Does anyone know where I can buy a new tang, or do I have to fab my own up?
67 5.3L Build |
its all about the +6 inches
Bub... do you have a tilt? That looks a lot like a van tilt column to me. Can you get a photo of the under hood end of it?
Yes, it is a tilt column. I'll take the pics tomorrow. I suppose the PO could have swapped the column. Thanks for the help.
67 5.3L Build |
Did you ever figure this out? I'm thinking I may have a van column too. I don't think I have a neutral safety switch and not sure I need one. Not even sure what it does honestly.
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
Yes, I found out that mine is a van column. I had to cut a new slot in it to mount the nss. It is a safety thing, so you don't start it in gear.
67 5.3L Build |
Thanks!
Did you end up buying a neutral switch made for a truck or for a van? If van, how did you decide which year to use?
I used Napa part# NS6537. I don't recall what it was for, but it worked out perfectly.
67 5.3L Build |
