Old 10-16-2010, 06:56 PM   #1
jake wells
my friend has a question his front brakes are locked on a 64 C20 longbed
if you try to move the brake pedal it is very hard and will not move at all.
the back brakes work just fine but the front ones are the problem.
jake wells is offline   Reply With Quote
Old 10-20-2010, 10:22 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: my friend has a question his front brakes are locked on a 64 C20 longbed
Hmmm,... if the brake pedal will not move at all,... how do you know the rear brakes are fine?
I would pull the front drums off and look at everything.
It could be a collapsed hose, wheel cylinder, etc.
Start at the wheel and start loosening brake line fittings and pressing the brake pedal,... until it releases.
You either have a mechanical problem or a hydraulic problem.
Also look at the master cylinder.
Keith
Convert to disc brakes.
Old 10-21-2010, 01:07 AM   #3
jake wells
he is trying to sell it to me too lol. but the front brakes are locked solid i jacked it up and tried to turn the front wheels but they are locked solid. so later when i get some time i will pull the drums and see what is going on.
Old 10-21-2010, 06:11 AM   #4
raycow
Stock single pot system, or has it been converted to split?
Ray
raycow is offline   Reply With Quote
