Old 10-16-2010, 07:29 PM   #1
Razr
Transmission question 1993 GMC Sierra ext. cab
I have a 1993 GMC Sierra Ext. Cab c1500 350 5.7 and i am experiencing shifting problems
Does anyone know what transmission it has i was told it was the 4L60 but also have heard its the a 4L60E? please help thanks
Razr is offline   Reply With Quote
Old 10-16-2010, 07:59 PM   #2
bwood
bwood's Avatar
Re: Transmission question 1993 GMC Sierra ext. cab
I believe it is a 4L60E. Look on the trans and see if it has handful of wires plugged into it the side, that would be a "E". There will be one plug on the back of both for the speed sensor, but the 700R4/4L60 will have just on plug on the side for the TCC. What are you shifting issues?
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 10-17-2010, 10:05 AM   #3
ChevyTech
May understanding is, all the automatics in 1993 C1500s were 4L60E transmissions.
Old 10-17-2010, 06:52 PM   #4
clinebarger
93 was the first year for the 4L60E. Only C/K 1500 & LD C2500s got them that year. 93 RWD cars (Corvette, F-body, B-body) still used the 4L60 (700R4)
clinebarger is offline   Reply With Quote
Old 10-18-2010, 11:04 AM   #5
windyhill1910
windyhill1910's Avatar
I have a 1994 4L60E with trans issues also, how big of a deal is it to put a 700R4 into it as I have a spare one of them ?
windyhill1910 is offline   Reply With Quote
Old 10-18-2010, 08:36 PM   #6
timcrow00
i have a 93k2500 and it is a 4l60e, since its electronic your best bet is to take it to a shop and let them hook it to the computer. its usually free and they will drive it and read the codes and give you better feedback than anything we can do over the internet.
timcrow00 is offline   Reply With Quote
Old 10-19-2010, 02:35 PM   #7
Razr
Well when i put it in gear to take it off 1st and 2nd gear have trouble shifting. When going to 2nd gear the RPMS raise up really high and the engine revs up really high before it shirts and 2nd gear has the same problem. however shifting to 3rd and fourth gear theirs no problem.
Old 10-19-2010, 03:54 PM   #8
timcrow00
if its slipping at all is most likely needs rebuilt, if it just revs up high before shifting it might be a selonoid. if it is a selonoid gone bad you will prolly have a check engine light on. either way a trip to a trans shop is your best bet. alteast to diagnose the problem
