carrier bearing?
ok guys i think the part im looking for is called a carrier bearing it holds up my two peice drive shaft to the frame i have snapped two of them now. the ones tha napa carry are stamped together at the bolt holes and dont seem to be working for me. i see that lmc trucks has a heavy duty billet one they sell .i was wondering if anyone has used it before i go spending $100 on one,and if there is any other companys that you guys know of that have a heavy duty one besides lmc?? thanks!
Senior Enthusiast
Re: carrier bearing?
Perhaps some of this information will be helpful:
http://67-72chevytrucks.com/vboard/s...arrier+bearing http://67-72chevytrucks.com/vboard/s...arrier+bearing http://67-72chevytrucks.com/vboard/s...arrier+bearing And here’s a link to a conversion kit: http://www.classicperform.com/Store/...Truck/CSBC.htm |
![]() Join Date: Feb 2010
#4 | |
I had one that broke like yours a few years back................The pinch welds that held the top to the bottom broke loose and dropped the driveshaft................I just welded them together and put it back on.....................It's been close to 8 years and it's still holding together fine................Hemmit
#7 | |
Senior Car Nut
![]() Join Date: Jan 2008
Which brings up a point. If you're breaking carriers often, Losthope, you may have a driveshaft balance or angle problem. I've not broken my made-in-china carrier since I fixed the driveshaft 10 or more years ago.
Larry |
#8 | |
This may be a stupid question, but ...
What advantages does a two piece driveshaft have over a one piece or vice versa? My 66 has a one piece, but my 65 parts truck has a 2 piece. Which is better and why?
![]() 66 Chevy C10 LWB ![]() |
![]() Join Date: Oct 2010
I'm interested in a one piece drive shaft upgrade, what are the bennis?
60-66 Nut
![]() ![]() Join Date: Mar 2007
IMO on a long bed a 2 piece is the best way to go. The one piece on a short bed is just fine. A lot of guys have trouble with the carrier bearings. But again IMO that is because they are using the whimpy light duty carrier bearings. I've never had an issue with the heavy duty carrier bearings as shown in these pics.
Is there a way to check and see if one is bad?
