Old 10-16-2010, 08:31 PM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
700r4 tranny
just had my tranny fix for burned up clutches.
i just got it back installed it and it wont change gears wondering if gov. would be an issue i also notice that when i did tighten down my torq convertor moved out away from tranny about half an inch or so
would that cause the problem ill take a pic in a bit
Sick5 is offline   Reply With Quote
Old 10-16-2010, 08:47 PM   #2
losthope
losthope's Avatar
Re: 700r4 tranny
i just got it back installed it and it wont change gears wondering if gov. would be an issue i also notice that when i did install the tranny my torq convertor moved out away from tranny about half an inch or so
i belive the converter is supposed to move away when you bolt it to the fly wheel about a half or so inch mine did , did you spin the torq converter clockwise before you put the tranny in it should turn and drop in two to three times getting past gears in tranny! if not might have to pull tranny again and also make sure your tv cable is adjusted right before you go driving it AT ALL or you can burn the tranny right back up!!!!! thats what happend to my 700r4 tv cable has to be adjusted!!! hope this helps..
losthope is offline   Reply With Quote
Old 10-16-2010, 09:28 PM   #3
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
yah i set the tv in the same place it was before.im just going to have to wait till monday
Old 10-16-2010, 11:39 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
Re: 700r4 tranny
Mine took many quarts to get it full.....not sure if it's there yet. How much fluid did you put in??
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-16-2010, 11:44 PM   #5
man-a-fre
Re: 700r4 tranny
11.5 to 12 qts fluid with new converter,is the flexplate on backwards? the raised pad for the converter bolts should face transmission.
man-a-fre is offline   Reply With Quote
Old 10-17-2010, 12:30 AM   #6
Captainfab
60-66 Nut
Re: 700r4 tranny
If you set the TV cable where it was before that doesn't necessarily mean it is correct. Could that have been why your tranny burned up before? Correct TV cable adjustment and geometry is very critical on the 700R4's
Old 10-17-2010, 10:43 AM   #7
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
flywheel broke and it pushed my torq out of socket when i was on the freeway.
thats why it burned the clutches up.i went around the block few times. and ajusted the tv cable in between. but nothing. i pull the the tv cable and it pulls it self back so that tells me that the tv is connected on the other side.. im also thinking my governor maybe took a ****. i really dont want to drive it too much im affraid to get the tranny to hot and burn it again.. if the pump is not pumping it wounded shift from revers to drive right?
Old 10-17-2010, 10:44 AM   #8
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
i put 11 qts
Old 10-18-2010, 12:49 PM   #9
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
I've read you can blow air thru the lines to unstick watever is stuck
in the vavle body. I'm going to try this if it don't work I'm pulling out and off to the mechanic it goes
Old 10-18-2010, 03:18 PM   #10
jchav62
1962 C-10
jchav62's Avatar
Re: 700r4 tranny
I recently put a rebuilt 700r4 in the '65. I believe it took 13-14 quarts to fill it.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-18-2010, 04:01 PM   #11
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
I talk to the tranny guy he said it might be the torq or just junk in the valve body?
Would the torq cause this?
Old 10-19-2010, 01:25 AM   #12
Captainfab
60-66 Nut
Re: 700r4 tranny
If there is junk in the valve body, either the builder didn't do a good job of cleaning the trans, or the trans cooling lines weren't flushed out prior to installing the new trans.
Old 10-19-2010, 01:38 AM   #13
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Re: 700r4 tranny
Hey Gilbert, let me know if you want me to swing by tomorrow to help you figure it out. I'm free all day.
kalirodding is offline   Reply With Quote
Old 10-19-2010, 06:37 AM   #14
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
I took it out. It's in the shop. I should have it back today. I'll let u know j.
Did you get yours up and running
Old 10-19-2010, 01:22 PM   #15
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
Update:
mechanic said alot metal flakes and slug
came from the torq convertor. 150 for another torq convertor.
I will pick it up later on today and install and cross my fingers and hope it works
Old 10-19-2010, 02:59 PM   #16
Maxxd07
Maxxd07's Avatar
Re: 700r4 tranny
Dont forget to flush the cooler out so there is no 3rd times a charm! Good to see you have an answer.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 10-19-2010, 03:04 PM   #17
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
I flushed the lines last night. All I did was blow air till no fluids came out.
I want to go pick it up now and install it but I'm at work. Suck!
Old 10-19-2010, 04:21 PM   #18
Maxxd07
Maxxd07's Avatar
Re: 700r4 tranny
I dont know how much metal was in it but it wouldnt hurt to get some cooler flush, the stuff in the can, and run it through to make sure there is no metal hiding in it at all. I know what you mean by being stuck at work and wanting to work on something you have had on your mind for quite a while. lol. You will have it installed and running in no time!
Couple 80s
Couple 70s
One 68
Old 10-19-2010, 04:36 PM   #19
padresag
Re: 700r4 tranny
if you are having a problem there as the capt says, it should be flushed to get the crap out from everywhere. blowing air through just doesn't cut it. it is like trying to blow a rad out
you'll need a recirculating pump
ron
padresag is offline   Reply With Quote
Old 10-19-2010, 04:37 PM   #20
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
How would I Be able to clean out the torq convertor. Hate to spen another 150 or so when this one I have is still new
Old 10-19-2010, 04:47 PM   #21
chillware
Re: 700r4 tranny
I would use more than air to flush that thing out, metal filings will cling to the inside, you need to get some coolant flush or just use some new tranny fluid and flush thru it..
My build thread: '66 Chevy
chillware is offline   Reply With Quote
Old 10-19-2010, 05:34 PM   #22
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
Good idea I'll use the tranny fluid
Old 10-19-2010, 07:46 PM   #23
Maxxd07
Maxxd07's Avatar
Re: 700r4 tranny
That isnt going to happen unless you can cut it apart and weld it back together, $150 is pretty cheap insurance if you ask me.
Couple 80s
Couple 70s
One 68
Old 10-19-2010, 10:54 PM   #24
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 700r4 tranny
ok well im done and ready to party. if any of you guys ever heard of my ***** and complain about a vibration coming from my drive shaft well problem solved it must of been my flywheel this hole time. 700r4 shift great no vib no at 55-60.. and thanks for the help guys
Old 10-19-2010, 11:12 PM   #25
62 Bowtie
62 Bowtie's Avatar
Re: 700r4 tranny
from the shop to runnin on the hwy same day, you da man
62 Bowtie is offline   Reply With Quote
