10-16-2010, 08:57 PM | #1 |
ok geniuses,window tint removal
i hate tint on my windows.plz someone buck up and give me the easiest safest way to get this crap OFF....ty
10-16-2010, 08:59 PM | #2 |
Re: ok geniuses,window tint removal
You only need two things. TIME and more TIME.
72 Cheyenne Super 80 Silverado Blazer 2wd |
10-16-2010, 09:01 PM | #3 |
seems like the sientists could creat a wipe on melt off solution,im trying goof off,widex,hate to break out the c-4
10-16-2010, 09:02 PM | #4 |
You can pull it off carefully trying to get as much off in one peice and then remove the remaining glue residue with ammonia. Please be in a well ventilated area if you go the ammonia route.
10-16-2010, 09:13 PM | #5 |
X2
70 Chevy SWB Fleet Project. 06 Lancer Evolution MR SE, stupid fast! 03 Ford f-250 crew cab, 6spd, diesel 56 ford f100 project My build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=426739 |
10-16-2010, 09:21 PM | #6 |
it dont just peel off,scraping and getting results but its gonna take forever this way,cmon some of you truck gurus someone must of found an easy way.....
10-16-2010, 09:32 PM | #7 |
peal it off in as big of pieces as possible and use glass cleaner that comes in an aresol can we use the brand sprayway its a blue and white can. it seems to break down the glue pretty well. use a razor blade also with the glass cleaner keeping the razor blade wet. carefull not to scratch up the window. its not to bad. Good luck.
10-16-2010, 10:00 PM | #8 |
Shortbed club member
Just removed some off my inlaws car.
Bug & tar remover worked pretty good. still alot of work.
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. |
10-16-2010, 10:08 PM | #9 |
the glue in newer tints break down pretty quickly with nothing more than windex with ammonia.
peel off the film ... soak the glue area with windex ... scrap with a NEW razor blade |
10-16-2010, 10:11 PM | #10 |
more ideas than money
I have used a heat gun with great success. It is still a slow and tedious process, but it helps the glue stay on the tint not on the glass.
Simple green also works well for what glue is left.
Randy 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
10-16-2010, 10:14 PM | #11 |
wanna buy some "tint free" windows?
you asked for advice! I have used the razor method... plus an hour of my time.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-16-2010 at 10:14 PM. |
10-16-2010, 10:33 PM | #12 |
Has more rust than truck...
They make tint-off. Peel off tint, spray and wipe. Should be found anywhere that sells tint....Walmart has it.
10-16-2010, 10:44 PM | #13 |
I used tint off when I peeled the old stuff off my Dodge before I retinted them.
Worked great.
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12 67 C-20,292,SM420,HO72 90 Dodge W250 Cummins,NV4500HD,205,D60/D80 93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70 |
10-16-2010, 11:06 PM | #14 |
My tint guy uses super clean. Don't cut it, use it straight, and use a LOT of it. I have done is several times with excellent success.
You should see him do it. He can do a window in 1 minute. Within 10 minutes, it will be re-tinted. |
10-16-2010, 11:17 PM | #15 |
I've used this method and it worked well. I don't really think there is a "quick and easy" way to remove tint.
-Scott- Last edited by sjarrett71; 10-16-2010 at 11:18 PM. |
10-17-2010, 12:19 AM | #16 |
Go to the Dollar Store and buy Ammonia and a cheap pump spray gun. Easy OFF.
10-17-2010, 12:41 AM | #17 |
Razor blade and paint thinner.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
10-17-2010, 01:25 AM | #18 |
Let the window sit in the sun and warm up, most of the glue comes off with the tint.
10-17-2010, 01:35 AM | #19 |
A former student of mine who is now a Washington State Patrol Trooper carrys a razor blade and tells the clown with the over tinted windows "you peel it off or I will". That usually gets the job done in record time. There are some around here that I would swear are painted black rather than tinted..
10-17-2010, 01:59 AM | #20 | |
"the other guy"
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
10-17-2010, 05:12 AM | #21 |
Moderator
It really depends on how long the tint has been there. The reason is two fold: 1. older tint may have become vulcanized to your glass due to age and temperature (hot/cold). 2. The composition of the adhesive. This is where you just have to use process of elimination. In science, we know that like polarities of molecucular stuctures disolve others with the same moluecular polaities. For example, oil based adhesives are disolved with oil based solvents. Likewise, water based adhesives are disolved with water based solvents. Many factors can still play into this. Anyway, use the process of trial and error. Try the windex/ammonia strategy, if that doesn't work, try goo be gone or some of the other products mentioned above. If the adhesive has been vulcanized to your glass, then only a lot of elbow grease, perserverience and time will do the trick...and of course, a sharp blade. Good luck. I'm sure you'll get it done.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
10-17-2010, 06:39 AM | #22 |
I used to install tint on office windows back in the late 70's-early 80's, so things may have changed.
Wet the window w/water. Using a sharp razor, we would score the tint (think wall paper removal). We then used water/vinagar and a drop or two of dish soap. Hold newspaper on window and spray w/solution. Keep it wet as best you can. Let the solution work (think paint stripper kinda thing). We usually started in the center so 2 people could work on the same window. Keep it wet, use a sharp razor in a holder avoids scratches in the glass. YMMV...HTH...don t. ..... |
10-17-2010, 07:27 AM | #23 |
Soak windows with vinegar water and soap solution. cut black plastic garbage bags and place on the wet window tint. Allow this to set in the sun for 3 or 4 hours. respray between the glass and tint to keep it wet as needed. If it has set long enough the tint should come off in a few pieces. Use a new razor blade to scrape the residue off. If you are concerned about placing scratches in the glass look for plastic razor blades (I have no idea where the tint guys get them from though).
This worked great in Phoenix az when the temps were 100+ but you would loose about a gallon in sweat when removing the tint. |
10-17-2010, 08:54 AM | #24 | |
10-17-2010, 01:20 PM | #25 | |
