Old 10-17-2010, 11:08 AM   #1
blackdawg
Blackdawg
Angry project rebuild 350 help
i have torn down the engine.had to remove the main caps first and had marked them took the crank out.it was hard to pull the pistons first.pulled all the rod caps and pistons are marked from 1-8.the only thing that worries me is i might have them out of order.i started the front of the block facing me and went right piston the left piston.so one two and so on.can a machine shop determine the sequence.which rod came from which journal on the crank.i concered i might have them mixed up.
blackdawg is offline   Reply With Quote
Old 10-17-2010, 11:40 AM   #2
chevybuldr
chevybuldr's Avatar
Re: project rebuild 350 help
Pistons are normaly numbered in order front to back. You got them all good.
chevybuldr is offline   Reply With Quote
Old 10-17-2010, 11:44 AM   #3
Greg63
Enjoy your truck
Greg63's Avatar
On a GM 350 the Drivers side, from front to back, are 1, 3, 5, 7. Passenger side, from front to back, are 2, 4, 6, 8.
Greg
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 10-17-2010, 04:05 PM   #4
blackdawg
Blackdawg
thanks guys that had me concerned
