White wall terror
3 on the tree
How much horse power can a 3 speed handle? I'm going to swap out my 307 for a much healthier 350 and want to keep the 3 speed in it.
Re: 3 on the tree
Unless you plan on lifting your front tires off the ground you should be ok. I know I guy with a 1965 mild rebuilt 350 and it's a 3 on the tree. It runs great. That shouldn't be a problem really...
Kid's Mechanic
Re: 3 on the tree
I agree , seem to be pretty tough trannys
Old Skool Club
![]() Join Date: Jun 2001
Re: 3 on the tree
You're not doing anything that hasn't been done many, many times over the span of ages of automobiles. I know guys who have gone through a couple of transmissions a week, but they were dealing with non-synchro first gear boxes and bad synchronizers while trying to speed-shift and impress their buddies. The gearboxes we have had since the mid-Sixties are better. Worst issue will be the linkage that gets worn and hangs up....and, that has nothing to do with horsepower.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Grandpa in the rustmobile...
Re: 3 on the tree
yeah it'll hold up (so far mine has)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
![]() Join Date: Jun 2009
Re: 3 on the tree
Hain't had no problems with mine. The 3-speed handles the the 350's horsies just fine. Now, the oil drain being right over the cross-members that came with the 307 and remained after the 307 left, that's another matter.
MJH |
Old Skool Club
Re: 3 on the tree
Here's a twist: Find a late Sixties/early Seventies G-van that has a 4-speed column and put a 4-speed in your truck. Can you imagine the fun that might bring when it comes to braggin' rights?
Suburban Hick
![]() Join Date: Aug 2008
Re: 3 on the tree
Must be pretty tough tranny's cause they use them in stock cars
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
I am a Referee of life.
Re: 3 on the tree
I bought one that had a worn non-synchro low tranny in it.It worked fine for about 2 years.I then bought a synchro tranny and installed with no other mods or repairs.I drove it for about 12-15 years before the engine hgave out.That truck is put away for a future project and that tranny is still in it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
White wall terror
Re: 3 on the tree
Thanks for all the replies guys, I was going to put a turbo 350 in it but my buddy sold me on the fact the I'm taking something away from the truck by doing that.
CAN'T FIX NOTHIN
Re: 3 on the tree
I had a big journal 327 and saginaw 3spd in a 67 camaro and would burn the tire's on a regular basis , ran it for year's , took it out when I found a T10 for the car , I sold the 3spd to a guy the raced a circle track dirt car with over 400HP , last I heard the 3spd was still working perfect , I myself have NEVER had a problem with one of the late 67 up 3spd's , now the 66 back 3spd's that have the non syncro 1st gear will break ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Old Skool Club
Re: 3 on the tree
The transmissions were a weak link and GM knew it. That's why the GTO used a Ford top-loader 3-speed for the standard 3-gear transmission.
#13 |
Re: 3 on the tree
The potential down-side on the 3-speed column shift is the possiblity of dirt getting onto the transmission as the tranny passes through the engine compartment. Since I don't plan to go mudding, I don't think I'll worry much about it.
#14 |
Gone to greener pastures
![]() Join Date: May 2007
Re: 3 on the tree
Back in '74 I bought a bottom of the line '74 C-10 (all I could afford) & it came off the assembly line with a 3550 & 3 OTT.
Never had a bit of problem with it.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#15 |
Re: 3 on the tree
I had two Saginaw 3 speeds and than went with a Saginaw 4 speed on the floor and every one the input shaft broke. I was using a Kevlar 12 inch disk with a diaphragm pressure plate this clutch was in or out no slip whatsoever. ended up putting in a th350 with a 3000 stall.
Fuzzy |
#16 |
Re: 3 on the tree
A lot of people will say you don't want a Saginaw in a serious performance application if you have good traction. I had one in a 66 GTO for years and never broke anything, but it had skinny tires.
ChevLoRay is right in saying that at least some of these cars came with the Ford transmission. Even though the Ford box had an unmistakable FoMoCo logo cast into it, GM was reluctant to admit that they were using Ford parts. All of the service literature that I have seen referred to it as a "Dearborn" transmission. My bellhousing was drilled with both bolt patterns, but the car shipped from the factory with the Saginaw. Ray Last edited by raycow; 10-20-2010 at 08:16 PM. |
