Old 10-17-2010, 10:56 PM   #1
vjjack04
vjjack04's Avatar
Frame Paint
Who has used a good frame paint/epoxy that you can recommend.
I am considering POR 15, Eastwood , or Summit...... Need to know
vjjack04 is offline   Reply With Quote
Old 10-18-2010, 12:07 AM   #2
OrrieG
OrrieG's Avatar
Re: Frame Paint
In 1985 I took mine down to metal where I could get to it without removing the cab (did remove the front clip and bed). I rattle can primed and painted it with 3 finish coats of Rustoleum Semi Black. It was my daily driver and saw plenty of off road use, snow and mud. It always got washed down good since I knew were the problem areas were. This time I took it down to bare metal. Where there was rust I used POR-15. Then urethane 2 part primer, then Nason Chassis Black (3 coats). I figure that will last for as long as I will and can easily be touched up.
OrrieG is offline   Reply With Quote
Old 10-18-2010, 11:21 AM   #3
samdjr74
Re: Frame Paint
I used POR15, it works well but makes a mess if you get it on your hands. Also if it's exposed to sunlight it turns grey unless you seal it with a top coat. For me it's the frame so I figure how much sun is it really going to get????
samdjr74 is offline   Reply With Quote
Old 10-18-2010, 01:58 PM   #4
bobinbc
bobinbc's Avatar
Re: Frame Paint
Just curious, how did that (the rustoleum) hold up?
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 10-18-2010, 02:03 PM   #5
LEEVON
Moderator
LEEVON's Avatar
Re: Frame Paint
I use black 2K epoxy primer. You can now get it from Summit pretty cheap a gallon at a time, with reducer about 2 gallons sprayable for maybe $80 shipped? You spray it direct to metal and it's very tough, it will scratch but usually just the surface and not all the way to metal. There's always something else to grind, cut, add or touch up and powdercoat or POR-15 require too much planning for my taste.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 10-18-2010, 05:39 PM   #6
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Frame Paint
Hey, for what it's worth I know a guy that has used Rustoleum Hammertone black on his '46 frame and it is WAY impressive looking.
In fact when I saw it I thought he'd had the frame blasted and powder coated...it's that good. He said the more he put on the more it looked powder coated. Not cheap, I think over $5 a can but for a rattle can approach it looked tremendous. Out here in California, rust is not that big an issue...usually!
Dan in Pasadena is offline   Reply With Quote
Old 10-18-2010, 06:15 PM   #7
OrrieG
OrrieG's Avatar
Re: Frame Paint
I put it on in 1985 and took the truck off the road in 1998. Areas were it was protected and on inside of frame did fine. Springs, axles and parts of the bottom and outside of the frame needed touching up over the years, the truck was my daily driver. I put about 75K miles on it. Many thousands offroad on gravel and dirt roads, like below. From 20 feet it always looked good to me. All of my disassembly pics are on an old Video tape that I need to get converted to newer format so I can't post those.
Old 10-18-2010, 10:24 PM   #8
vjjack04
vjjack04's Avatar
Re: Frame Paint
Folks,
Thanks. This is good info. I posted a similar question in my build thread, but really should have just discussed this here (I guess). I am considering the POR 15 just for the durability....but I want to spray it on (using a spray gun) but am a little unsure. Would be interesing to spray it on an then use the hammertone after that........wonder how that would work.....only problem is the hammertone top coat probably wouldn't resist fuel, etc.....
Old 10-18-2010, 11:04 PM   #9
LEEVON
Moderator
LEEVON's Avatar
Re: Frame Paint
The thing that scares me about spraying POR-15 is that it is purported to have high polyiso's and if not done very safely could land you in a world of hurt.
Old 10-18-2010, 11:39 PM   #10
hsdropout
Re: Frame Paint
The POR 15 brushes on very easy and flttens out like glass. I plabn on doing my frame with it. It is sandable and you can top coat if if you roughen it up a bit. Good stuff.
hsdropout is offline   Reply With Quote
Old 10-18-2010, 11:44 PM   #11
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: Frame Paint
sorry to jack your thread, but I have POR15 and just got my truck back from blasting, have a small patch to weld in and "c" notch to cut in, then what? quick marine clean metal ready and brush on or just metal ready and brush on?
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 10-19-2010, 03:25 AM   #12
OrrieG
OrrieG's Avatar
Re: Frame Paint
POR-15 sticks to any and everything. If you spray it any overspray on your concrete, walls, tool boxes, paint suit, mask, will be permanent. I don't know what you use to clean your gun but I would not use one I could not stand to toss. Go read the POR site info about over coating. They recommend overcoating it while still tacky. If it is going to be exposed is has to be over coated or the UV turns it a dull grey. I brushed all of mine so it was easy to control. If you get it on your skin, plan on it being there for 7-10 days until it falls off with the dead skin layer. If you google it there is a very funny message board from about 10 years ago about a guy that got some on his personal part and the attempts to get it off. Also once exposed to air it starts curing, I have not been successful in keeping it from hardening once the can is open so I only get the quantities I can use in one application. Luckily there is a local store that sells it for the same price as you can get it on line.
Old 10-19-2010, 07:11 AM   #13
Dan Bowles
AD Addict
Re: Frame Paint
Anybody have any issues with POR15 changing color? I hear if you don't top coat it, it will "whiten."
I have always used Tractor Supply tractor paint on my old Jeep frames and plan to do it again for my S10 under my '51.
Dan Bowles is offline   Reply With Quote
Old 10-19-2010, 08:36 AM   #14
ClassicDreamer
Re: Frame Paint
I just used a product based in NY. Its called magnet paints. I first got there samples in the mail and BEAT THE CRAP out of it! Hammers, Screw drivers, anything I could get my hands on. I bent the hell out of the sample and NOTHING! No chips at all. Impressive stuff. I bought a gallon. Already applied 1 coat on a fully boxed s10 chassis and didnt even make a dent in the can. Plan on applying another 3 coats.
ClassicDreamer is offline   Reply With Quote
Old 10-19-2010, 09:52 AM   #15
54 jimmy
54 jimmy's Avatar
Re: Frame Paint
i used zero rust on my frame fairly cheap and easy to use. i had good results with it. you can also paint over this stuff to. comes it different colors too so your not limitted to black or silver. www.zero-rust.com
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 10-19-2010, 09:57 PM   #16
kaycee
kaycee's Avatar
Re: Frame Paint
I went and got some equipment paint from the farm and ranch store when I did my 69 5 yrs ago still looks good.You spray it on with a cheepie spray gun I did a primer and 2 topcoats for about $25.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 10-23-2010, 10:49 PM   #17
mexgrhd68
mexgrhd68's Avatar
Exclamation Re: Frame Paint
satin black rustoleum.........
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 10-24-2010, 08:15 AM   #18
blackdiesel
blackdiesel's Avatar
Re: Frame Paint
YES, I brushed it on my frame. It looked great so I didn't topcoat, like said it's the frame, not going to see the sun. Wrong, My truck didn't live in the garage, and in a year my frame looked dull gray. Yes it was a 4x4 with 35's on it. I was not inpressed. Now I just sandblast, prime and paint, looks alot better down the road. So if you have to use POR 15 read and fallow the can, and top coat. IMO
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 10-24-2010, 11:22 AM   #19
Wheelie
Re: Frame Paint
por 15 if you dont want to prep a lot. Otherwise I would blast and paint the whole frame. Powdercoat is the best if you have the money IMO.
Wheelie is offline   Reply With Quote
Old 10-24-2010, 11:37 AM   #20
68gmcdually
68gmcdually's Avatar
Re: Frame Paint
We have been a distributor for Bill Hirsch in Canada for years, after importing the products and using them personally for a number of years before that. It has the same problem as POR-15 like said before that it needs to be top coated but what we do is to spray the frame first with the black miracle paint, then top coat it with chassis black. We have been really happy with their products.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
