10-17-2010, 11:19 PM | #1 |
hows any one made electric fan shroud??
i guess i have to make one for my 61. i just got a spal fan 2470 cfm. its cooling it just not cooling good. its running 180 and then going down the road it jumps around from 180 to 210. so why does the fan go up high on the rad?? and if anyone has made a electric fan shroud help would be great right now.
10-18-2010, 12:57 AM | #2 |
Proud Americano
Re: hows any one made electric fan shroud??
is it a pusher or a puller.is it on constant or thermostatic switch.how is it mounted.
Tattooed Cuban Trailer Trash. putting the cart before the horse since 1964. |
10-18-2010, 01:17 AM | #3 |
its a puller on the motor side. its mounted on the radiator core useing metal and the fan sits in the middle of the radiator.
10-18-2010, 10:04 AM | #4 |
Registered Loser
Summit Racing has fairly cheap aluminum shrouds for electric fans.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
10-18-2010, 10:18 AM | #5 |
So does Jegs. They are slightly different sizes than summits so one may work better than the other for you. Speedway has some universal ones too. You may be able to get a local HVAC or metal working shop in your area that has a brake to make one for you. then you could just cut out the hole for your electric fan. I just got a Jegs universal aluminum radiator and their kit that came with the shroud and fan. Seems pretty nice so far.
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
10-18-2010, 10:22 AM | #6 |
you would probably need to use a sheet metal brake to make one yourself so you can flare it out on all four sides so it doesn't sit tight against the rad. measure the core of your radiator and see if one of the universal ones can be adapted to fit.
10-18-2010, 10:31 AM | #7 |
roaster pans work well too,,not my work,,my club brother Da Tinman
10-18-2010, 10:48 AM | #8 |
VERY creeative!
10-18-2010, 11:10 AM | #9 |
Check out Alan's build thread. It has alot of good information in there. Here is a link to the shroud http://67-72chevytrucks.com/vboard/s...248460&page=98
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
10-18-2010, 12:13 PM | #10 | |
Proud Americano
speaking from experience.
10-18-2010, 12:44 PM | #11 |
10-18-2010, 09:29 PM | #12 | |
1 thing at a time is progress.
Alan
Philippians 2:14-16 |
10-18-2010, 10:52 PM | #13 |
yep. Recycled a piece of bed frame or 1"x1" angle welded togather with four holes in each corner and then a piece of 24"x24" galvinized steel folded on the sides 1/2" to make a shallow pan then cut the hole and self tap screwed fan to it then tack weld the shroud to the frame.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
10-18-2010, 10:56 PM | #14 |
Resistance is Futile
Here's mine. Aluminum with 2 12'' fans. I went with 2 so they would be offset from the waterpump pulley.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
