Old 10-18-2010, 01:54 AM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Fuel Lines 68 cab to a 71 chassis
Got the motor in the frame today. A couple of notches for the headers. Some questions arose over the fuel tank from the '71 that I'll be using in the '68 cab that has '71 "Everything Else"
I believe the '71 has the EEC fuel tank. It had the vent tube running up the back space behind the passenger in the cab, which I removed and kept, the canister next to the battery box in the engine bay, which I jettisoned, and a mess of fuel lines running from around the fuel pump to the back.
One , in particular, seems strange. It's *outside* the front frame rail and curves up looking to accept a rubber hose (to the cannister?). I think I can figure that there is a feed from the tank (goes back thru the cab floor?), a "return", and a "vent". Is it ba good guess that all three of these hoses go back to the fuel tank and up thru the floor of the cab? The '71 cab (gone to the rust collector/squisher), had two holes in the cab floor, and the '68 has only one.
So, what do I actually need? All three? Which is which? I looked on the explosion on LMC and I can't be sure. I'd really like to just use the supply line and whatever else is ABSOLUTELY necessary. Whatever that would be.
Thanks.
Here's the sparks flying today. The gas is turned off (moved outside) and our eyes and ears are covered.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 10-18-2010, 02:53 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Fuel Lines 68 cab to a 71 chassis
Too dark right now to go look for sure, but if you look at the charcoal canister the ports are marked. One line goes to the tank, one to the PCV and another to a vac port on the carb. Hope this helps.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-18-2010, 08:11 PM   #3
Hubscrub
Cruzin
Hubscrub's Avatar
my 71 has one line to pump and the other line is just a vent under the cab now
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-19-2010, 05:31 PM   #4
raycow
In that case, you dont NEED to install the canister. It is part of the emission control equipment, and in CA I believe a 68 model year vehicle is exempt from emissions testing.
Ray
raycow is offline   Reply With Quote
Old 10-20-2010, 09:09 PM   #5
crakarjax
crakarjax's Avatar
I'm doing the same exact thing, and my current plan is to use a '68 sender (or EEC sender with the vent outlet capped) and get a vented gas cap for my '72 tank. I have yet to hear form anyone that that would be a good way to go and I haven't located a vented cap that will fit.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
