![]() Join Date: Aug 2009
Got the horse power now i need stopping power....
Can anyone tell me what power brake units will bolt up to my 1970 1/2 ton 4/4 with 4 wheel drum breaks..... and what parts will be needed....
Re: Got the horse power now i need stopping power....
rubber fuel lines start great big fires
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
if you can find it, a 71-72 will be basically a bolt up. A 73-87 or so will also work but you moght need an aftermarket bracket and or a different rod going to the pedal.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Tuffstuff performance has a nice chrome setup
1969 C10 stepside 1973 Cheyenne Blazer |
Check this out...I added booster to my own drum system.
http://67-72chevytrucks.com/vboard/s...d.php?t=410167 |
Active Member
Booster install pics.....
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
Never try to teach a pig to sing; it wastes your time and annoys the pig! ![]() ![]() My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
