Old 10-18-2010, 11:20 AM   #1
Alvin
Never Done?
Alvin's Avatar
Dual Compressor Plumbing
Trying to get my truck mobile before winter sets in and a big part of that is wiring and plumbing the air ride. I have dual Thomas compressors (one 327, one 337) and dual 3 gallon tanks. I'm trying to figure out what is required to run both compressors.
Is it possible to run both compressors to a T fitting connected to a check valve on one of the tanks? My concern was with one compressor feeding back into the other.
I only have one check valve so running one compressor to each tank isn't an option.
Thanks!
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 10-18-2010, 12:04 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: Dual Compressor Plumbing
I can't see any reasonable way to plumb 2 compressors with only 1 check valve. If it were me, I'd buy another check valve and run a compressor to each tank and have the 1 tank fill the left side and the other the right side...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-18-2010, 12:10 PM   #3
Alvin
Never Done?
Alvin's Avatar
That was my conclusion as well. Guess I'll be going shopping afterall!
Old 10-18-2010, 01:12 PM   #4
Shane
Shane's Avatar
Do the Thomas compressors not have check valves built in to the leader hose?
Not familiar with them is the reason I ask.
Shane is offline   Reply With Quote
Old 10-18-2010, 01:48 PM   #5
Alvin
Never Done?
Alvin's Avatar
Correct, no leader hose on the Thomaseses.
Just to get things moving I'll be hooking up one compressor and tank at this point. Once I get some of the other projects done I'll install the second compressor and tank.
