Old 10-18-2010, 12:39 PM   #1
BIG HEAD
one piece floor
Anyone that has put in a new one piece floor panel in cab. How does it fit? Does it line up good. Pros? Cons?
MY POND TRUCK BUILD http://www.67-72chevytrucks.com/vboa...d.php?t=297393
BIG HEAD is offline   Reply With Quote
Old 10-18-2010, 12:50 PM   #2
ebfabman
Re: one piece floor
Check out this thread. You may find some helpful info there. Also use the search, its been done many times. Good luck...its not that hard...eb
http://67-72chevytrucks.com/vboard/s...light=ebfabman
ebfabman is offline   Reply With Quote
Old 10-25-2010, 03:26 PM   #3
BIG HEAD
Re: one piece floor
i wanted to know from someone who has first hand experince how does it fit. how things line up afterward?
Old 10-25-2010, 04:55 PM   #4
ebfabman
Re: one piece floor
Umm.....I am the one who installed the one in the build thread in the link above. In fact I've installed two of them. Like most aftermarket sheetmetal, it will need some work to get everything fit right. If you read through the build thread you can see the areas that need work. Not hard to do if you can weld.
