10-18-2010, 06:20 PM | #1 |
My Barn Find
Okay...so I know its not a 67-72 but I stumbled onto it looking at a rust bucket of a 69.
This is a 75 camper special with a 454 and a legitimate 57,000 miles. Been parked for at least 15 years. My question is this: What needs to be done to it to get it running? Spray the cylinders with some good lube and try to turn over the motor or just go ahead and pull the heads and put in new gaskets? I know the tanks will have to be cleaned out and the Carb rebuilt.....thoughts? Best thing about it is the price and no rust!!!
70chevytruck |
10-18-2010, 07:30 PM | #2 |
God is good!
Re: My Barn Find
Looks like a '73-'74 model. I'd definitely drain/change all the fluids, clean/flush the tank, rebuild the carb, change the hoses and belts, and it "should" start right up if it ran when parked.
10-18-2010, 07:49 PM | #3 |
Getting Old; Going Broke
Re: My Barn Find
Has a 73/74 grille, also 73/74 park lights, has a drip molding, so I'm guessing it's actually a '74. Awesome find, anxious to see what it looks like after a bath.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
10-18-2010, 09:45 PM | #4 |
Re: My Barn Find
Make that a shortbed and that would have been a dream find for me. Looks like a super solid truck cant wait to hear how well she runs
when you get it started.
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
10-18-2010, 10:02 PM | #5 |
Re: My Barn Find
When you said it had been parked for a while you weren't kidding! You can't even see through the windows! A little cleaning and it will look great! Can't wait to see more pictures
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
10-18-2010, 10:43 PM | #6 |
Re: My Barn Find
My 85 sat for 15 years in hot Arizona sun, For under 1k I got it back on the road and still running strong.
Here is what I did to mine. It was very simple. Get a fire extingusher. Pull carb off, soaked in a bucket of gasoline and changed out all the gaskets and the small parts that came with kit. Take your fuel line loose going into the fuel pump and run some hose from the line going to the fuel pump into a container you want to fill with bad gasoline. If you have compressed air grab a blow gun and wrap a rag around the end and stick it into your fuel filler. Pressurize the fuel tank and the gas flows out of the lines into the container, this takes a while. Put on your rebuilt carb and change your fuel pump, the diaphram is most likely dried up and bad in your fuel pump so save the trouble and just change it. Instead of using the metal line going from the fuel pump to carb just get some nipple fittings and run a rubber hose from the fuel pump to carb and put a clear plastic filter in. It will get plugged with crap often and after a while clears out, the plastic filter is just easyer to change and dignose fuel problems. Change your engine oil and filter and add half a bottle of sea foam. Fill the tank with fresh gas and add the rest of your sea foam to that. Pull your plugs and squirt some Marvels Mystery oil into your cylinder walls. Replace with properly gaped plugs. Change out your wires, cap and rotor. crank your motor without starting to slowly build oil pressure and evently let it start and idle. for a while, watch your temp guage. If it runs decent move onto the cooling system and oils in your Trans, transfer case and differentials. If it does not run good pull your valve covers and check all your push rods. My engine had stuck valves that broke the push rods. On top of all that I replaced: water pump, Radiator, hoses, belts, and the power steering pump. |
10-19-2010, 07:31 AM | #7 |
Re: My Barn Find
Nice find! god I love those 73-78 trucks.
Keep us updated!
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
10-19-2010, 08:51 AM | #8 |
Re: My Barn Find
Nice find man. Looking forward to the progress.
10-19-2010, 10:00 AM | #10 |
Slots go on anything!
Re: My Barn Find
kinda like a time capsule. Very cool.
1974 Jimmy- 5.3/4L80e/NP241 |
10-19-2010, 10:04 AM | #11 |
Re: My Barn Find
can't wait to see what waits underneath the dust...
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
10-19-2010, 10:11 AM | #12 |
78K & 79C Jimmys
Re: My Barn Find
now thats a find
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-19-2010, 02:16 PM | #13 |
Arrived on a Pale Horse
Re: My Barn Find
Build a plastic dome over it and let off some insect bombs to de-spider it....
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
10-19-2010, 02:22 PM | #14 |
Re: My Barn Find
A low mile big block square...nice find
10-20-2010, 03:18 PM | #15 |
Re: My Barn Find
The other great thing about it is the 8 track tape player and the CB radio....you remember what those are, right? Even comes with a few 8 tracks.
70chevytruck |
10-20-2010, 07:13 PM | #16 |
Re: My Barn Find
Awesome find, I want to see it outside and clean. Wish we had those around here.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
10-20-2010, 07:18 PM | #17 |
Insert Title Here
Re: My Barn Find
nice find, but why was it parked?
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
10-20-2010, 07:20 PM | #18 |
Re: My Barn Find
Nice find
69 chevy stepside (project) 2006 Silverado Z71 Ext. cab 2005 Saturn VUE (wifes dd) |
10-20-2010, 08:00 PM | #19 |
Re: My Barn Find
That would be a dream come true a roundeye big block lwb in a barn or shed!!!!
1979 GMC Sierra Classic Freshly lowered 5 inches |
10-21-2010, 07:23 AM | #20 |
Re: My Barn Find
The owner was getting older and the truck had some minor problem so they just parked it and started working on it...just never finished.
Hopefully the engine is still okay....waiting on title.
70chevytruck |
10-21-2010, 09:06 AM | #21 |
Re: My Barn Find
nice find, post up some pics of it cleaned up as soon as you can...
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
10-21-2010, 11:28 AM | #22 |
Insert Witty Text Here
Re: My Barn Find
That looks like my barn.
Congrats on the find! Slonaker |
10-21-2010, 11:55 AM | #23 |
Re: My Barn Find
I used to have fun with CB's...probably going to put one in my truck when it is finished.
10-21-2010, 11:59 AM | #24 |
IT Guy/ Father/ Chevy lover
Re: My Barn Find
nice find.
78 Chevy (Pictures) SOLD 79 Chevy LWB (pasture) 83 Chevy LWB (crushed rusted beyond repair) 02 TrailBlazer SOLD 03 VW Passat wagonSOLD 95 extended cab silveradoSOLD (still in family) 05 Crew Cab Silverado 5.3 (The Turd) WTB: 66 El camino Technology Specialist aspiring to be a gear head. |
10-21-2010, 01:18 PM | #25 |
Re: My Barn Find
VERY COOL!!!!!!!!!!!! I can't wait to see it cleaned up also
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
