Old 02-28-2003, 08:11 PM   #1
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
help! stuck distributor
k i was tryin to set the timing on my truck and a loosened the bolt just fine but i just cant get the distributor to turn. whats the deal?
~1980 c10 chevy scottsdale~
~2.5/4 drop 305/th350c~
c10scotty is offline   Reply With Quote
Old 02-28-2003, 10:03 PM   #2
Tracy Focht
Tracy Focht's Avatar
Are you sure it's loose, and the vacuum advance canister isn't hitting anything?
Tracy Focht is offline   Reply With Quote
Old 03-01-2003, 07:33 PM   #3
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
yes its loose, i could turn the bolt by hand, and the canister is free. anyone??
Old 03-01-2003, 11:36 PM   #4
CT-Truckster
CT-Truckster's Avatar
the same happened to me on a 79 f#@d i use to own. that thang was stuck bad, wouldn't turn for nuthin. i at first thought maybe it was hung up in the block or something but since it ran good i figured maybe not. I guess all the gunk that had settled around where it seated on the block had turned to some kind of undiscovered super duper metal adhesive. the distributor was up front so i took off some the acc. brackets and stuff and was barely able to get a small pipe wrench with a piece of pipe on the end of it(i figured it's a f@#d what the hell) and after busting a few guts it finally popped loose. i pulled it out of the block and didn't see anythng that might have been making it stick like that so i set the timing and everything was fine.
CT-Truckster is offline   Reply With Quote
Old 03-01-2003, 11:47 PM   #5
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
well thats not very encouraging...thanks though
Old 03-02-2003, 12:02 AM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I have heard of people using the friction type oil filter wrench to break them loose. I would be afraid of breaking something, though.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-03-2003, 12:18 AM   #7
solidaxel
solidaxel's Avatar
iF IT BRAKES GETTING IT OUT......it needed to be replaced anayway
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-04-2003, 01:19 AM   #8
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
Seen it happen in Fords because they are actually sunk into the intake but never in a Chevy. Someone might have used sealer on both sides of the gasket. Try leaving the bolt loose and taking it for a short "low RPM" drive. The heat and vibration might be enough to break it loose.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 03-04-2003, 09:41 PM   #9
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
thanks 82 silv, i might try that. my auto teacher is kinda wierd though so he might not let me in class...if not ill do it later
and good point solidaxel...may be time for an msd billet distributor, and an msd 6a hei kit
Old 03-06-2003, 01:01 AM   #10
solidaxel
solidaxel's Avatar
Sounds like a justifible excuse too me!!
LS 3 4L70E
